Question about Precor EFX 546i Elliptical Version 4
Error 30 - Precor EFX 546i Elliptical Version 4
    Problem Solver:
  • 7 Answers
As an 18 year fitnes repair technician of fitness equipment (and a six year advanced certified Precor tech) I can say without a doubt that an error 30 is NOT "no power to the upper board". think logically...if there's no power to the upper pca how can the upper pca tell you there is no power? good luck! PS: you can ask nicely and someone may give you the Precor Repair Manual we all get when we take the Precor Training Seminars. OH...an error 5 is usually caused because you hit a button just before the unit had finished booting up and you interupted the self diagnostic.
Posted on Oct 30, 2012
  • 15 Answers
Error 30 is no power to upper PCA or upper console. I believe in the 546 there are 2 interconnect cables, one lower that runs from the back to the bottom of the mast, and an upper, that runs from the console, down the mast. They meet at the front and connect using what's known as a mid-point connector (technical, I know). Unfortunately, there's no real test available, aside from checking the 3 connections other than substituting out for a known good cable. You can remove the console and ensure that the cable wasn't plugged into the CSAFE port on the console board. Sometimes, if a machine has been transported or moved, this can happen as the CSAFE and LOWER PCA ports are identical, but it's printed on the actual circuit board under it. Now depending on the serial number sequence of the machine, the cable can route a few different ways, although most use a 2 interconnect cable system with a mid-point connector (little black female/female connector) I would be able to get a little more detailed if I had a serial number, the first 4 digits are enough to establish the particulars about a machine.
Posted on May 28, 2010
  • thedream66 Oct 11, 2010
    I have this issue. I did not physically see the machine working properly prior to this issue, but I was told it was working fine before I took the (handle)bars off and disconnected the electronics to move it through a narrow doorway...and I have no reason to doubt it was working fine. Upon re-assembly, I'm receiving the ERR30 message after seeing an "ERROR 5 - Stuck Key" message.
    Funny you should mention it, because the only part of disassembly that I did not note specifically was the CSAFE and LOWER PCA positioning. I do not remember which one the cable was plugged into. Therefore, according to your advice above, I removed the circuit board, but there is nothing on the underside to indicate which is which. Regardless, however, whether the cable is plugged into the CSAFE or LOWER PCA (whichever is which), the ERR30 message appears, so this leads me to believe the "error" is occuring elsewhere.
    What I believe to be the serial number is 75D18N0033. Another number on the machine that could be the serial is 250Z4A. Any suggestions/help will be greatly appreciated.
How to fix err,30 on canon t3
Have a look here for error code 30
http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/
Jun 20, 2014 | Canon EOS 1100D Rebel T3 Body Only Digital...
Error code -SE-
Hi maaki41,
The error code SE stands for a keypad is held down for longer than 10 seconds. If you were not holding down a button then you have a defective key pad because of the sensor error. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 17, 2011 | Maytag Over-the-Range Microwave
During reheat and popcorn settings - the error code F4 appears
Hi hoodrd,
If you are encountering F4 error code from your Amana oven this is because you have an Open Oven Temperature Sensor. This error requires a replacement of new oven temperature. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Jan 17, 2011 | Amana ACO1860 Microwave Oven
Error 11
ERROR-11, 12, 17, 30 Dirty disc Clean disc.
ERROR-11, 12, 17, 30 Scratched disc Replace disc.
ERROR-10, 11, 12, 15, 17,
30, A0
Electrical or mechanical Turn the ignition ON and OFF, or switch
to a different source, then back to the CD
Feb 20, 2010 | Pioneer DEH-1800 CD Player
Error 12 and 15 what is that
30, A0
Feb 18, 2010 | Pioneer DEH-P2900MP CD Receiver...
My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Jan 19, 2010 | Maytag 30 in. Electric Single Wall Oven...
Windows XP Error: category 102 event id 1003
look like a system crash.
try to go into save mode and do a scandisk
if not, remove any newly install hardware or software.
restart the laptop.
Nov 10, 2008 | Microsoft Windows XP Professional
PHASER 7700 ERROR 30
try this
The following functions will generate a Tech Rep Fault:
  • Error: 30: Belt Home Too long
  • Errors: 12, 13, 14, 15: ATC-YMCK Sensor Fail
  • Errors: 40, 44: Fuser Main/Sub Lamp Temp Too High
  • Enter Service Diagnostics
  • Highlight NVRAM Access and press OK
  • Highlight Clear Tech Rep Faults and press OK
  • Highlight the Tech Rep fault to be cleared and press OK
If you have had the error 3 consecutive times , you do need to send the snippet to the printer to clear the error. The instructions how to do it are in the download.
Other things. You may need to replace the accumulator belt.
You may have toner backed up in the waste auger, you can clean that out and replace the waste bottle.
Cause:
The plastic tab attached to the cleaning blade assembly was broken, this tab opens the cleaning blade waste assembly when the belt is lowered .
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. The waste toner from accumulator belt cleaner could not reach the waste bin and jammed the augur. This caused the grinding noise by stalling the accumulator belt motor. This causes an error 30 code to be displayed.
The belt cleaner does come as a separate part 016-1889-00 and is very easy to fit and much cheaper than a new belt assembly.
Error 30 is a Tech Rep fault. After three Error 30's, the NVRAM Clear Tech Rep Faults will need to be reset to be able clear the Error 30 message.
Mar 04, 2008 | Xerox Phaser 7700 Laser Printer
Precor EFX 546i Elliptical Version 4 Logo
668 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
