Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer spins, no heat, after 10 min lights flash
Same description, but no solution!!!
  • Frigidaire Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
Posted on May 28, 2010
My 2004 Pontiac grand am se1 acts like door is open and interior light stays on also does t lock on its own when in gear and lights don't blink and horn not honk when locking with key bob
Door ajar switch problem more then likely or wiring issue . The BCM - body control module won't turn off interior light , let door lock because it think's the door is open . The door ajar switch is a input to the BCM .
The first thing would be to have it checked for DTC'S - diagnostic trouble codes . Also check with an enhanced scan tool to see if the BCM shows ajar switch data (open or closed ? Do you know about body electronics ?
Body Control Module
The various BCM input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The Body Control Module functions include the following:
A/C compressor request. Refer to Air Temperature Description and Operation
Remote Function Control. Refer to Keyless Entry System Description and Operation
A/C cooling Fan. Refer to Air Delivery Description and Operation
Audio Delay Power. Refer to Radio/Audio System Description and Operation
Exterior and interior lighting control. Refer to Exterior Lighting Systems Description and Operation
Daytime running lights (DRL)
Automatic lighting control
Fog lamps
Interior lighting. Refer to Interior Lighting Systems Description and Operation
Battery rundown protection (Inadvertent Power). Refer to Interior Lighting Systems Description and Operation
Chimes. Refer to Audible Warnings Description and Operation
Key-In-Ignition
Head Lamps On
Seat Belt Not Fastened
Turn Signal On
Park Brake Warning
Door Ajar Warning
Check gages
Gage control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Instrument cluster indicator control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Theft deterrent. Refer to Theft Systems Description and Operation .
Engine coolant level sensing. Refer to Cooling System Description and Operation .
Washer solvent level sensing. Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
Key-in-ignition sensing. Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
Seat belt use sensing. Refer to Seat Belt System Description and Operation .
Brake fluid level sensing.
Parking brake state sensing.
Rear compartment interface. Refer to Power Door Locks Description and Operation
Horn interface.
Door lock interface. Refer to Power Door Locks Description and Operation
Bulb Check. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Oct 24, 2016 | 2004 Pontiac Grand Am
Pump works, but there is no pressure
If pump is primed properly, either the impeller has come off or is blocked. You may have to be a bit more descriptive if this isnt the case. ie: Pump model/make, suction description, size type length height etc. discharge description
Apr 02, 2015 | Plumbing
What is the code p1080 for a 1999 jeep grand cherokee laredo
Error Code P1080 Description Nothing listed for this error code
If there are multiple descriptions of the diagnostic code listed above, please read below to see if any of the descriptions are known to be for a specific model or year of Jeep vehicle.
Sep 05, 2014 | Jeep Grand Cherokee Cars & Trucks
How do you get to the description ?
Once viewing a video, simply scroll down and directly below the video player will be where the description is located. To view the full description, click the "see more" button. To edit the description of your own video, click the pencil.
Jul 21, 2014 | YouTube Computers & Internet
Comparing Political Philosophy Theories
fixya site answers technical questions
we do not do your assignments for you
Aug 12, 2017 | Philosophy Toys
I need a driver for my acer aspire m1640
Download Acer Aspire M1640 Chipset & AHCI SATA Driver For Windows XP Description: Intel Chipset and AHCI SATA Controller for Win XP
Download: Chipset-and-AHCI.zip
Download Acer Aspire M1640 Audio Driver For Windows XP Description: Audio Driver for Win XP
Download: Audio.zip
Download Acer Aspire M1640 Network Driver For Windows XP Description: Wireless WLAN Wifi, Modem and Ethernet Lan Card Driver Package For Win XP
Download:Wireless-Modem-Lan.zip
Download Acer Aspire M1640 ATI Graphics Display Driver For Windows XP Description: ATI VGA Graphics Display Driver For Win XP
Download: Part1: ATI.rar.part1 Part2:ATI.rar.part2 (Download both parts and extract using winrar)
Download Acer Aspire M1640 Nvidia Graphics Display Driver For Windows XP Description: Nvidia Geforce 7050 VGA Graphics Display Driver For XP
Download: NVidia.zip
I hope this information will be helpful. Thank you for using FixYa!
Jan 09, 2011 | Computers & Internet
Repair to gas gauge 1999 malibu goes up and down what to look for and radio goes up and down sound
It sounds like - from your description - that you may have a possible electrical short. I wish your description of your problem were a little more descriptive.
When do these conditions happen???
The Wrench,
Oct 10, 2010 | 1999 Chevrolet Malibu
What synthetic motor oil to use in 2007 v/w beetle
Most any 5w-40 fully synthetic oil with be fine in your car.
but here is a list of the recommended oils from Volkswagen.
VW/Audi Approved Engine Oils
Oil Quality Standard VW 505.01
(note: not all oils listed are available for sale in the US)ALL 505.01 Approved Oils are SAE 5W-40 Viscosity
Manufacture: Audi/VW
Description: part number G 052 167 A2
Viscosity: SAE 5W-40
Manufacture: AD Parts
Description: AD SDI
Manufacture: Addinol
Description: Addinol Light MV 0546 PD
Manufacture: Agip
Description: Agip 7004
Manufacture: AMAG
Description: Gamaparts Super LL TDI
Manufacture: Aral
Description: Aral Tronic 431
Manufacture: Avia
Description: AVIA TDi 505.01
Description: Avia Turbo CFE PD
Manufacture: BP
Description: BP Visco Special V
Manufacture: Bucher AG
Description: Motorex Profile V–XL
Manufacture: Carat
Description: Carat ad–Diesel PD–Oil
Manufacture: Castrol
Description: Adamol Multitop PDI
Description: Castrol 505 01
Description: Castrol GTD 505 01
Description: Castrol TXT 505 01
Description: Cepsa Star TDI synt
Manufacture: Chevron
Description: Havoline 505.01
Manufacture: Delek
Description: Delek IDI
Manufacture: Denicol
Description: Denicol Pro Syn 4
Manufacture: Elf
Description: Elf Excellium DID
Manufacture: Engen Petroleum Ltd.
Description: Engen Formula 505.01
Manufacture: Esso
Description: Esso 505 01
Manufacture: Eurol
Description: Eurol Turbo DI
Manufacture: Fina
Description: Fina Delta 505.01
Manufacture: FL Selenia
Description: Aktual Top Synth
Manufacture: Fuchs
Description: Fuchs TITAN Supersyn Plus
Description: Labo Syntha High Tech Synthese
Manufacture: Galp energia
Description: Galp Formula 505
Description: Galp Formula TD 505
Manufacture: Gedol
Description: Champ
Manufacture: Ginouves
Description: York 742
Manufacture: Gulf
Description: Gulf GDI Extra
Manufacture: Igol
Description: Igol Process 505.01
Manufacture: Ina
Description: INA 505.01
Manufacture: IP
Description: IP Sintiax 505
Manufacture: Kuwait Petroleum
Description: Q8 Motoroil 505 01
Manufacture: Liqui Moly
Description: Liqui Moly Diesel High Tech
Manufacture: Mapetrol
Description: Mapetrol 505 01
Manufacture: Meguin
Description: megol Motorenoel Super Leichtlauf Technology
Manufacture: Minerva–Oil
Description: TSH 5W–40 505.01
Manufacture: Mitan
Description: Alpine PD Pumpe Dã¼se
Manufacture: Mobil
Description: Mobil Synt S Special V
Description: Mobil Syst S Special V
Manufacture: Mogul
Description: Mogul Forte Racing S
Manufacture: MOL
Description: MOL Dynamic Synt
Manufacture: Motul
Description: Motul Specific 505.01
Manufacture: MRD
Description: Motor Gold Supertec PD
Manufacture: Oel–Brack
Description: Midland Axxept
Manufacture: Oest
Description: Oest Leichtlaufã¶l 505.01
Manufacture: OMV
Description: OMV syn com diesel
Manufacture: Panolin
Description: Panolin Daytona
Manufacture: Pentosin
Description: Pentosynth 5W–40 TS*
Manufacture: Poweroil High–Tech–Schmierstof
Description: HD SL CF PD Pumpe/Dã¼se Synth.
Manufacture: Quaker State
Description: Quaker State Diesel Plus
Manufacture: Rafinerija Modrica
Description: Optima 505 01
Manufacture: Ravensberger Schmierstoffvertri
Description: Ravenol VPD
Manufacture: Rothen Oil
Description: Rothen Extrasint
Manufacture: Shell
Description: Shell Helix Diesel Plus VA
Manufacture: Sinopec
Description: Blue Spirit
Manufacture: Slovnaft
Description: Madit 505 01
Manufacture: SRS Schmierstoff Vertrieb
Description: Wintershall Leichtlauf–Motorenã¶l PD
Manufacture: Startol
Description: RASANTA SPECIALSYNT
Manufacture: Statoil
Description: Statoil SuperWay 505.01
Manufacture: Sunoco
Description: Sunoco Ultra semi synthetic
Manufacture: SWD
Description: Concep–Tech Synth.
Description: swd Primus Synth.
Manufacture: Texaco
Description: Texaco Havoline 505.01
Manufacture: Total
Description: Total Quartz 505.01
Manufacture: Unil Opal
Description: Opaljet 505.01
Manufacture: Valvoline
Description: Valvoline DuraBlend Diesel motor oil
Manufacture: VAPS
Description: VAPSOIL 505 01
Manufacture: Westfalen AG
Description: Westfalen Megatron
Manufacture: Wolf
Description: Wolf Masterlube Synflow PI
Manufacture: Wã¼rth
Description: Triathlon Special PD
Manufacture: Yacco
Description: Yacco VX 505
Manufacture: YPF
Description: YPF Elaion Full Performance TDI
Jul 11, 2009 | 2001 Volkswagen Golf
Frigidaire GLEQ2152ES Electric Dryer Logo
112 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
