Question about Panasonic DMRES15 DVD Recorder
I have a Panasonic DVD recorder model DMR-ES16 and the problem is that itdo not want to read DVD's or not record too. I would like to know if you have the replacement laser pickup part number. I'm an electronic technician in Amos, Quebec, Canada ---> http://www.tecbrochueletro.com/homepage/home.html Thank you.
    Genius:
  • 1,112 Answers
Hi:
First the problem may not be the laser, the most common problem involving DVD or CD players failue componet is the Spindal Moter. The motor that spins the Dics, the bushing go bad in motor and causing them not to spin up or spin a reduced speeds, the laser will not lift or pickup and read the TOC (Table of Contents) until the spindle motor sense terminal reports back to the micro that it is spinning at the proper speed. So before replacing the laser Traverse unit assembly as its called by panasonic I suggest you fist check the spindle motor and the Home posistion switch, this is the switch the optics assembly hits when its closest to the spindle motor, to let the micro know its in home start posistion, But if you just insist on ordering the traverse unit the part Number is as follows RFKNES15P this part comes with the Loading Motor/Optical pickup/spindle motor/tray loading belt.Now this part number is for the DMR-ES15P which uses the same part as the 16, But panasonic makes two models of the ES16 and they are the DMR-ES16PC and the ES16PL I am not sure which version you have but if it ends with pc or pl these models have a complete DVD drive in them like a Computer, and you will need to replace the digital board also, it comes as complete assembly if you need parts to these models I would be happy to help you.
Posted on May 27, 2010
No read on my 2008 panasonic dvd recorder DMR-EZ485V
Insert a lens cleaning disc into it and let it play. If this do not help you, the optical pickup unit to your playder is faulty, and should be replaced.
Apr 30, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from panasonic.com, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
Will not read DVDs
When I place a blank or ore-recorded DVD into mt Panasonic DMR-EZ47VEB it indicates NO READ. Can I solve this problem?
Feb 20, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
My Panasonic DMR-EX85 is locked into region 2 Can you help to to make is Region Free please Thank you Roger
TRY DMR-E85 DVD Recorder Firmware Update
Version DL-106
  • Compatible Models DMR-E85HS
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs
  • http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-E85HS.D#ts
    Oct 26, 2009 | Panasonic DMR-E85H DVD Recorder
    PANASONIC DMR EZ47 WONT FINALISE
    NEED DMR-EZ47 - 475 DVD Recorder RRT Firmware Update
    Version RRT
  • Compatible Models DMR-EZ47VK, DMR-EZ475VK
    1. Enables the DVD Recorder to download the new V-Chip Regional Rating Table Data Stream.
  • icon-download.gifDownload
    http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-EZ47VK.D#ts
  • Sep 14, 2009 | Panasonic (DMR-ES45VS)
    En la pantalla aparece set 1 no funciona el control remoto
    Presionar ENTER y el boton numerado 1 (por SET 1, 2 por SET 2, 3 por SET 3) por mas de dos segundos.
    Mar 02, 2009 | Panasonic DMRES15 DVD Recorder
    Read failure o DVDs on Panasonic DMR-EX75
    You need a lens cleaner to clean the lens of ur DVD recorder..
    Dec 09, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
    "NO READ" on Panasonic DMR-EZ27 DVD Recorder
    good day 2 you,, ,, i have some little advice on you,,
    just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
    and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
    PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
    GODBLESS U
    Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
    This is the most common problem, in most cases the burner must be replaced.
    May 03, 2017 | Panasonic DMR-E80H DVD Recorder
    Panasonic DMR-E50 won't recognise blank DVD's only
    You can only record to dvd-ram or dvd-r NOT dvd-rw!
    Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
    Panasonic DMRES15 DVD Recorder Logo
    294 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Jaime Hernandez
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
