Question about True TD-65-24 Commercial Refrigerator
My true back bar cooler dosent cool it is not iceing over
Compressor fan is running an so is condensing fan it is a true tbb-4 how do i rule out compressor
    Director Badge:
    Uploaded 100 video answers.
  • True Master
  • 488 Answers
Posted on Jan 26, 2015
  • True Master
  • 1,151 Answers
If you can gain access to the compressor, you will see 2 copper lines going to the compressor. One is smaller than the other. VERY CAREFULLY lightly touch the smaller line while the unit is running. If the compressor is running, that line will be extremely hot.
Start there.
Let me know if I can be of further help.
Posted on Jun 29, 2010
How do you remove the evaporator cover on a Tbb-2 cooler?
PDF]True Manufacturing Company, Inc. - Fixitshop.com
https://fixitshop.com/manuals/TECHNI~1.PDF
Top Removal for TBB and TDD ... Top Removal for Various Coolers - TSSU, TWT, TUC ... End Cap Replacement-T-Series Swing Door ... GDM 2 Door Cooler IDL Light Diagnosis ... If you keep the Condenser clean you will minimize service ...
[PDF]installation - True Manufacturing
https://www.truemfg.com/assets/...Website/TDB_TBB.../tbb_english.pdf
Your TRUE cooler when properly maintained will give you many years of trouble-free service. TO LOCATE REFRIGERANT ..... Removing bracket from skid. Removingbracket from cabinet. 1. 2 .... tab holding the door cord slides out the back. ... The switch is located on the front of the evaporator housing toward the front of .
Nov 08, 2015 | True TBB-2G-S Stainless Steel Beverage...
I have a True tbb-2g that recently froze some beer in bottles and also a lot of moisture on bottles still in cooler that I have not enjoyed yet ! it is no froze up and compressor was replaced 3 years
Is the condenser clean and clear? Is the fan running? Sometimes when the fan fails the compressor runs and runs and runs. First thing you need to do is go to the supermarket and pick up a red stick thermometer and find out what kind of temperature you have. Try setting the temperature warmer. Is the coil iced up at one end? If it is there is a good chance the system has a leak and needs a look at from a tech with some tools. Hope this helps good luck.
Oct 21, 2014 | True TBB-2G Commercial Refrigerator
TRUE TBB-2G Cooler is leaking water from the fan
I would guess the water is dripping from an ice ball or buildup in the coil either from an inlet side of the coil blocked by an accumulation of dirt and dust or paper or such. Second, if you leave the door open for lengths of time ice will build up, also an over heated over loaded condenser will cause ice buildup. In any case if you shut it down, let the ice melt, clean the coil, keep the door closed as much as possible and if its hot where its sitting let it have some air it should improve. Last thought, if there is a refrigerant leak in the system ice will accumulate at the end of the coil, the compressor will stay on longer than normal and this water drip is letting you know a service call is coming soon. Hope this helps and good luck.
Aug 12, 2014 | True TBB-2G Commercial Refrigerator
Temperature stays at 60 doesn't change even when adjusting thermalstat
Inside cooling coil frosted up? turn to run inside fan only until melted away & restart. Possible reasons for this a)dirty condenser down at the compressor which could be brushed but DON'T bend the fins. b0 refrigerant leaked out thru a existing crack. c)poor compressor pumping ability. d) excessive load of warm air entering the cabinet so the system can not reach the request temperature & shut off the compressor to allow that frost to defrost off the evaporator(inside fins) or the system does get too cold & then frosted to the point & never shuts the compressor off so it can defrost.
Dec 12, 2013 | True TBB-2 Beverage Cooler
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
We have a true upright, glass front beer cooler. TBB-4-G refrigerated back bar. The bottles and cans right in the middle are icing up and forming huge blocks of ice. we have turned up the thermostat,...
Check your evaporator drain pan and the outlet for the condensate water, and make sure the drain tubing is clear. That water is supposed to drain outside the box.
Aug 30, 2011 | True TD-95-38-LT Beverage Cooler
I have a fairly new True tbb-2gs which is on a dedicated 120V/15A circuit...has had problems in past with condenser cycling. That problem went away after unplugging and replugging the cooler back into the...
You have to verify that the compressor is running. Don't assume that it is just because the fan is running. the compressor may not be running. If compressor is running, good possibility that it is low on refrigerant. Most common and obvious.
Aug 18, 2017 | True TBB-2G-S Stainless Steel Beverage...
True TBB-24GAL 48" wide unit turns on and shuts down real loud
THE COMPRESSOR IS DAMAGED INTERNAL JUST USE TLL IT DIES OR REPLACE NOW IT PROBABLY HAD A 5 YR WARRANTY ON COMPRESSOR
Jun 18, 2009 | True TBB-24GAL-60 Stainless Steel Beverage...
True TD-65-24 Commercial Refrigerator Logo
287 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
