Question about Jenn-Air JMV8186AA Microwave Oven
Audible sound has faded almost to nothing. I checked for adjustments in the manual and there were none for this problem. What would be the problem?
  • Jenn-Air Master
  • 9,047 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If you still have toruble, feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 28, 2010
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
Hi, I have a hotpoint cooker hood and the lights keep fading out then flashing on again.
Sounds like loose/burned wiring at the plug or spur unit .Check mains feed
Feb 22, 2011 | Hotpoint Microwave Ovens
Works fine, except the beeps suddenly went silent. Examples: 1. When food is finished cooking, no beep any longer. 2. When pressing any key to set for cooking, no beeps any longer. Never thought that...
On page 21 of the owner's manual (online here), that's covered under "AUDIBLE SIGNAL ELIMINATION":
If you wish to have the oven operate with no audible signals, touch CUSTOM HELP, the number 2 and STOP/CLEAR.
To cancel and restore the audible signal, touch CUSTOM HELP, the number 2 and START/MINUTE PLUS.
Feb 16, 2011 | Sharp R-1520LW 1000 Watts Microwave Oven
Dead Microwave
Check your plug and change the fuse there also.
You might need to rechange the 20 amp 250v fuse behind the control panel again due to the recent spark.
If none of this works then i'm afraid a certified technician needs to check the power packs and boards
May 22, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How would i know if door switch it is not working on my microwave
Use a multimeter and set it to ohms or continuity (the multimeter could have an audible symbol and when you touch both leads should make an audible sound, most of them work this way), if it's a normally open switch you should have continuity (a sound from the meter or a zero or zeros) when the door is closed only and no sound from the meter when the door is open. If the switch it's normally closed you should hear a sound from the meter when the door is open and no sound when the door is closed. If you have a sound from the meter with the leads connected at each side of the switch regardles if the door is open or closed your door switch is bad or if you don't hear a sound from the meter regardles if the door is open or closed the door switch is bad.
Apr 04, 2009 | General Electric Microwave Oven
No sound from unit when making pad selections
From page 24 of the owner's manual:
Audible Signal Elimination
signals, touch HELP GUIDE, the number 2 and
STOP/CLEAR.
To cancel and restore the audible signal, touch HELP
GUIDE, the number 2 and START.
If you don't have your owner's manual, I've uploaded it to our site for your convenience:
http://www.microwavedisplay.com/dcm24_om.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
May 07, 2008 | Dacor DCM24 Convection/Microwave Oven
The touch pad fades out and now won't work.
We regularly repair these for customers nationwide with our guaranteed $39.95 service.
Full details of our service are at http://www.microwavedisplay.com but if you still have questions, please reply back.
Dec 09, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Whirlpool Microwave Model MH3184XP
This is most often caused by a bad magnetron "scrambling" the controller, a bad connection on the controller, or a controller failure. Try to use the "timer" function of the oven. Make it count down without cooking for about a minute. If it works, then it's more likely to be a bad magnetron. If it still fails, it's probably a problem on the controller. We repair these nationwide by mail for $39.95 in most cases. For more information see our listing here on FixYa: http://tinyurl.com/yzjozk
Sep 22, 2007 | Whirlpool MH3184XP Microwave Oven
Jenn-Air JMV8186AA Microwave Oven Logo
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
