Question about Jl Audio Stealthbox Single 10" Chevy Blazer 4Dr 1995-2004 Medium
I have a 1995 chevy blazer it keeps vapor locking it turns over and won't start I have to let it sit a good 1/2 hr then it will start and go again the fuel pump was changed last year could it be theromastate, fuel filter ????????????????
  • 1,871 Answers
Hello! Most common cause is a defective Evaporator Purge Solenoid...Located behind the right front wheel...Two wire connector; Dark Green/White and Pink...Average cost at your local auto parts store is $25...
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Posted on May 28, 2010
  • David Burbee
    David Burbee May 28, 2010
    Hello again! forgot to tell you that I am; Guru..........Saailer
2003 Saturn L200 vapor lock?
no such thing as vapor lock with fuel injection,need to check fuel pressure,running out of fuel is really hard on the fuel pump
Dec 14, 2013 | Cars & Trucks
1995 Kawasaki GTR1000 will not start when hot
Hi, Dean and the usual suspects are:
1. Faulty ignition coil.
2. Faulty spark plug cables.
3. Faulty temperature sensor.
4. HISS light not going off.
5. Faulty starter motor.
6. Valves adjusted too tight.
7. Spark plug gap too wide.
8. Fuel has vapor lock.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Won start when warm
She cranks but won fire
Kawasaki Concours 1000GTR Service Manual
OEM Parts for Kawasaki
Kawasaki 1000GTR Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 16, 2017 | 1993 kawasaki GTR 1000
Vapor lock? On a 4.3. 2000. Chevy. Blazer
Not really possible.
Vapor lock was when liquid fuel would vaporize in the steel line or carburetor from excessive heat.
Since your Blazer is fuel injected, the fuel can not vaporize in the line.
May 10, 2013 | Cars & Trucks
Alarm won't shut off on 1999 Chevy blazer 4x4
Is it factory alarm or aftermarket??. Try using the key to lock and unlock the doors driver and passenger then turn the ingnition on with the key and leave it in the key on engine off position for a few minutes and start the vehicle
Oct 14, 2012 | Cars & Trucks
Does not start for a while,. the after half hr then it starts again.
You did not give me alot of information to work with here but I will try to help you out any way real fast. If you try to start the car and it just won't turn over when it is hot chances are that your starter is bad, and needs replaced. If your car turns over fine but just wont start chances are that you may be getting a fuel vapor lock. I hope that this helps you out.
Aug 26, 2011 | 1993 Honda Accord
'95 Chevy Blazer driver's sit wire doen't have
the wires between the door and frame are probobly broken from opening and closing so much....run into it a lot...cheap fix is to cut the rubber boot off with a razor knife and splice in a piece of wire....tight working in there and make sure you seal them up with heat shrink and lots of electrical tape,,,good luck...Lee
Aug 21, 2009 | 1995 Chevrolet Blazer
1997 chevy blazer ignition switch
1997 blazer put car in park shut it off but, key won't turn far enough back to come out
May 12, 2009 | 1997 Chevrolet Blazer
My chevy drives for 45mins then shuts off
Your ignition module is bad. Known to stop working when it gets hot and work again after it cools off. Replace it. Good luck
Feb 10, 2009 | 2001 Chevrolet Blazer
Jl Audio Stealthbox Single 10" Chevy Blazer 4Dr 1995-2004 Medium Logo
289 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
