Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine overheats and stops
We have a 2004 Craftsman 17.5 hp 42 in riding lawn mower. After my husband performed 'normal' maintenance last season (changed the spark plug, changed the oil, new air filter, new fuel filter, fresh gas) the engine started overheating and will stop running, especially if the blade is disengaged. This has only gotten worse this year. Any ideas on what he might have done wrong, or where to look for the problem?
Thank you,
Pam Pagnotta
  • 821 Answers
Hello,There is a idler pivot plate on the mower that must be cleaned and lubricated regularly, from the left side of the mower deck if you look in the middle of the mower deck while someone engages the mower(with the engine off) you will see the pulley try and move,there is a 3/8 bolt that comes up through a bushing that this pivots on, soak that area with wd-40 and see if that improves the movement. Be sure not to get any wd-40 on the belt or pulleys. Always try and keep that area clean and lubed.
take care.
Posted on May 27, 2010
My 22 hp craftsman riding lawn mower gets really hot after10 to 20 minutes and backfires and loses power
You may have a mouse problem. Check the shroud (motor cover) to see if there is shredded paper or other material under shroud. If the mouse shreddings get in the fins on flywheel it will cause the engine to overheat. Remove shroud and clean underneath.
Sep 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas somehow is getting into oil reservoir. Twice now. Initially thought it was operator error. After second time, know it is the mower. Craftsman 17 hp 24 inch riding.
I would check the carburetor float to ensure that it stops gas flow once it is full. It is possible that the float is stuck and gas is getting to the top of the engine and getting past the rings.
Gary
Jun 29, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I was engaging the blade on my 17 hp craftsman lawn tractor and the engine died. Now the engine won't turn over. ???
the motor wount turn over if in fact the belt is tight around the motor pully. remove the deck belt then also make sure there are no switches not working.
Nov 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine stops
Hello
Have a look at the saftey switches.theres one under the seat.and one under the blade engage lever.
There may also be one under the hood near the fuel tank.
May 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
We need the electrical diagram for a 17 HP Craftsman 42" cut riding mower. Model-311707 Type-0321-E1
this is as close as i can find.. take a look and see if you can use this diagram...good luck. go to page numbers 34 and 35
http://www.hammerwall.com/Download_Manual/18200/
Apr 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Electrical schematic
i need a diagram for the ignition switch on my craftsman mower
....7 prongs all labeled with letters sure what 3 are for not other 4
Apr 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Missing oil dipstick
Hello:
You can Purchase a New Dipstick from your Local Small Engine Service Center or Online.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
85 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
