Question about Pool & Spa
Proline model 8D-1--1N11CB - Just opened out pool, the filter is very noisy and not sucking very well... it is 2 years old and it worked fine last season It's a grinding kind of noise...
2 Suggested Answers
  • 151 Answers
SOURCE: Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Posted on Jan 17, 2010
I,ve just opened my pool and when I backwash the filter the water comes out at very high pressure. This is not normally the case certainly not for the last 10 year. Is there a problem with the filter,
No.
Nothing in filter will increase water pressure. Whatever water the pump sucks in will flow out of whatever port is open, in the case of backwash, a Waste port open. So... What the pumps takes in, you will see flow out when you backwash.
No problems that I can think of to look for.
May 13, 2015 | Pool & Spa
I have a proline pool pump model # SD-15-1N11CC and it worked fine until I back washed my pool and now it stopped working. It makes a humming noise and nothing else.
C. MOTOR HUMS, BUT DOES NOT START—
Check for:
1. Centrifugal switch stuck in open position.or if capacitator start could be bad capacitator. Possible loose connection.
2. Binding of motor shaft. (something stuck in impeller) Does motor turn free. IF not check for jamed impeller. If it she sp2605x7 you can view a manual here:
http://www.haywardnet.com/products/Manuals/pdfs/manual113.pdf
Aug 17, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Just opened pool for 3rd year, I cleaned the filter added new powder, motor very noisy and must bump the filter every 30 minutes
Filter needs to be disassembled, cleaned, acid washed and reassembled. Motor probably needs to have new bearings installed or be replaced
May 11, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
New Intex FP621 4000 Pool Pump Noisy
I have a 16 x 48 intex pool with the 1inch inlet and outlet. I purchased the intex 4000 pump. The attachments are too big for the inlet and outlet so i then purchased the adapters. The plungers are very noisy and allow air to get into the pump. I removed them and hooked the hoses up to the adapters directly. That worked as long as the adapters were new. This year the seal comes loose and allows air to get into the pump. I even tried allowing the top nut to be loose to allow air to escape. This year nothing works. The pump is just too strong for the holes. I was considering cutting the holes bigger and glueing seals on there but i was concerned about creating weak spots in the pool. I am tired of spending money on it so i did the redneck thing. I can say that because well, you might consider me one. I took the inlet hose off the connector and plugged the hole with one of those little black things. I took the hose and run it up through the hole in between the liner and the poles and down into the pool. If you run it over the top it will not work correctly. Take the hose and tie them together between the two sides as best you can to keep the hose in the pool. If you look at the smaller intex pools that dont have holes, that is how they have the pump hooked to the pool. VOILA! You have an airtight inlet to the pump. You do not need to do that to the outlet because its not sucking water its just pushing it. So, just hook the hose up as you wish. When you need to clean the filter, I put wash clothes in the hoses to plug them and voila. No air gets into the filter. Done! It is actually keeping my pool clean this year. Also, i purchased one of those aqua vacuums and it does work great for this pool. Once you get the big stuff, sweep it with a pool broom and the filter will do its job. You can vacuum these pools with the filter type pumps. Next time, i will purchase a sand filter and be done with it. Happy swimming with less work.
Jul 26, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Proline 1.5 hp pump gets hot and trips breaker.
motor is locked up in the motor are two bearings they will rust if they are set up for a while.you can take the back off the motor and where the shaft goes thru the houseing take a pair of needle nose plires and try to free it up.
Jul 03, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Unit is 2 years old, worked fine. now it trips the GFI after a few sec's running. no other things are pluged into the line at all.
Motor windings are overheating and expanding inside the potting seal causing an intermittant short to ground. Need to replace the pump.<!-- from fixya rte -->
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Jun 03, 2009 | Hayward 1.5 Hp Northstar High Performance...
Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
May 17, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Pool & Spa Logo
96 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
