Question about Kenmore Elite 45986 Front Load Washer
When I start the wash on my 4T, the water coming from the hose inside seems to have a very low pressure. Is my hose clogged? and is that preventing the water from coming out normally and cleaning clothes thoroughly?
  • 5,911 Answers
This problem is commonly attributed to a water inlet valve that has become clogged with sediment, or kinked/clogged fill hoses.
If you live in an area that has hard water, or if you use well water, it is common that have calcified deposits, rust or sediment build up in the lines over time. You can attempt to clean the sediment screens in the hoses (if your hoses have them) and/or the inlet valve on the back of the washer. Cleaning with a 50/50 solution of distilled vinegar and hot water can often restore normal flow. If this does not work, however, the valve needs ot be replaced. The following link explains how to access the valve and replace:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
Scroll down to the section that discribes the steps required for replacing an inlet valve. I've included part resource websites as well.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on May 28, 2010
Washing machine not filling
Check the screens at the point where your water hoses connect to the washer. These often get clogged with calcium. A simple vinegar soak or cleaning with a brush will often solve this problem
1. Turn off the water supply at the valve
2 Place a towel or bucket behind the washing machine to catch remaining water coming from the removed hose
3. See if the screen (often cone shaped) is inside the washer side or the hose itself.
Remove the screen, clean it, and replace.
I hope this works.
Mar 08, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Honda pressure washer 2400 psi worked fine yesterday, today the pressure is low, seems to work fine except the level of press sure is low any suggestions?
Check for an inline filter on the water hose connection, the low pressure side. Depending on your water quality and if any spiders made homes inside your hose, they can get clogged pretty easily.
Jun 07, 2011 | Garden
Water will not stop and the washing cycle will not start.
You have one of the following;
Too low drain hose,9Must be 30" high),
Drain hose is too tight in drain(no air gap),
Defective water valve(leaking water through),
Pinched or clogged air pressure tube to water level switch,
Defective pressure switch.
May 08, 2011 | Maytag Washing Machines
My Whirlpool front load washer has an error code of F-20 and will not finish the wash cycle. What is wrong and how do I correct it?
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
drain_inlet_hose_wall.jpg Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
fl_hot_cold_back_of_washer.jpg Is the water pressure less than 10 psi?
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
helogo.jpg See also: Why HE High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
To remove the error display, press Pause/Cancel twice.
hcz_003_web_env1.gif If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTES:
  • On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
  • If the error remains on the display, and all of the other conditions above have been checked, call for service.
NOTE:The above article dircty from whirlpool customer help site.
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water valve has to be shut off at faucet to
This may be caused by a pressure switch malfunction or a water inlet valve that is leaking by. The following link explains how you can determine which one may be causing your problem:
Is this a simple problem of the washer continuing to fill with water when its not in use? Does the washer overflow? Does the water shut off after the cycle ends? These are some good questions that can help lead you in the right direction.
Check the small air hose that runs from the bottom right hand side of the wash tub to the pressure swtich. If this hose has come loose from the pressure switch from the air dome on the wash tub, the pressure switch will not sense the pressure differential coming from the wash tub as the unit fills. Also, if the air hose is cracked, ripped, split, or clogged somewhere, you will get the same symptoms.
If the water inlet valve is determined to be the source of your problem, follow the steps provided in the link on how to replace one. These are simple and inexpensive repairs. I've also included web sources that you can refer to for part numbers.
If you need further assistance, please post back and let me know. I hope this helps lead you in the right direction.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dishes are`t clean ,arms dont spin during wash cycle
what is the model # how mutch water is in the basin?
Jun 28, 2009 | Dishwashers
My washing machine over fills then begins the agitating cycle but the water continues to enter the machine until it comes over the top
YOUR WATER PRESSURE SWITCH HOSE IS CLOGGED YOU NEED TO ACCESS THE INSIDE OF THE CONTROL PANEL AND LOOK FOR A CLEAR HOSE EITHER BLOW OR USE A SMALL BLAST OF COMPRESSED AIR TO CLEAR THE CLOG(15-20PSI MAX)
Apr 16, 2009 | Fisher Paykel EcoSmart GWL15
Slow to take water
Slow fill problems are usually attributed to a clogged inlet valve. If you live in an area that has hard water, or if you use well water, it is common for the inlet valve to become clogged with rust or sediment over a period time. Follow these steps:
- First, you need to make sure the fill hoses are not kinked. Many home owners push the washing machine too far against the wall in an attempt to save space and unknowingly kink the inlet hoses. Leave about a foot of space between the washer and the wall to prevent this.
- Next make sure you are getting the proper water pressure through the fill hoses by removing them from the back of the washer and placing them inside the wash tub. Turn on the water back on and see if water comes through the hoses unobstructed and forceful.
- If you have good water pressure, and the hoses are not kinked or clogged, check the inlet screens on the back of the washer (this is where the fill hoses connect). Clean them (if necessary) with cotton swabs to remove any debris. You can attempt to remove the valve and flush it with distilled vinegar too. Vinegar is often used to remove hard water deposits and can help in some situations.
- If all preliminary steps do not work, I would recommend replacing the inlet valve.
I hope you find this information helpful. If you require additional assistance, please post you make and model number along with any additional questions, so I may be able to assist you better.
Nov 07, 2008 | Washing Machines
Water pressure
there is a screen in the inlet valve. it could be clogged. remove the hose from the inlet valve of the washing machine and look for a screen inside the inlet valve.
tnx 4 using fixya.
drcool
Sep 09, 2008 | Whirlpool Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
126 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
