Question about Sharp AFR120FX Air Conditioner
Does not heat air
Works fine for cool but preheat blinks on for a long time so we dont get hot air
  • 36 Answers
What is the Tempeture outside?
Posted on May 27, 2010
DONT KNOW WHAT SIMBLES ON REMOTE CONTROL ARE EG HOT COLD ETC
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Mar 20, 2011 | Mitsubishi MSZ09UN Air Conditioner
Thermador P304CS error code 4 preheat blinks then 3 heat blinks
I wanted to post this up in case someone has trouble finding an answer and what worked for me. I found somewhere else that the 43 code (4 preheat;3heat) blinks was specific to the cooling fan or the temp sensor. I had started to remove the temp sensor off the back wall of the oven but was unsure where the wire ran to. There is a specific Ohm value it should have around 1080 I think (not 100% postive).
What I found during that search is what solved the oven problem for me. On the top of the range, if you pull off the grill grates and remove the center stainless cover you can access under the burners. You can do this without removing any wires or hardware. In the back of this area is a small cover held in by 4 screws. Remove that. Underneath it is the cooling fan switch. It is a mechanical switch that when the fan kicks on it pushes a metal sail that then causes a connection in the switch letting it know the fan is operating. This switch had a little bit of corrosion on one terminal but it is also prone to getting dirty. Clean it off and try to restart the oven. The sail should move forward and the switch makes connection. For me once it was cleaned and any corrosion cleaned off, my oven worked just fine. This is a pretty easy check with the 43 code since it does not involve a lot of invasive work. Hope this helps someone.
Mar 07, 2010 | Thermador Kitchen Ranges
AMANA AC unit Blows heat in cooling mode
These valves do get stuck. They energize for cool and in the dead postion they heat. Your valve is stuck or not energized. Can you here it click or try to energize. If you dont hee the click you do not have voltage to the valve. The valve is powered thru the defrost board. So that might be your problem. If you have voltmeter. Take the two wires off the valve and turnit on cool you should get 24 volts. If you have 24 volts the valve is bad. If you do have voltage to the valve tap the valve while energized and sometimes this will loosen them up. If the board or valve is bad you will have to call a service tech. Russ There is only so much you can do.
Jul 25, 2009 | Whirlwind FH-778 Air Conditioner
AIR Problems
try making sure the duct work is ok
Apr 09, 2009 | 2001 Jeep Grand Cherokee
Heater does not blow hot air
you might need to change the thermostat.. when the thermostat isn't working correctly it prevents the hot engine coolant to circulate and give you heat.
Mar 01, 2009 | 1994 GMC Yukon
Clock on comi boiler
it may be the preheat setting on the boiler for the hot water circuit. do the radiators get hot when the boiler fires up with the time clock off ? if not then there is nothing to worry about if it is only on for a short time.
Jan 04, 2009 | Heating & Cooling
Ac and heater work great but go off. Then Ac blows Hot / heater cold air
I got a bigger coat to wear! while I find time to look into it further. I appreciate knowing there is more help available and will try the Primo Asist plan later. thank you louie
Nov 03, 2008 | 2001 Honda Insight
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Sharp AFR120FX Air Conditioner Logo
35 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
