Question about Stanley Tools Hammer Staple/Tacker - PHT150C
Jammed PH150 Stanley Sharpshooter Tacker
Our Stanley Sharpshooter PH150 tacker is jammed and needs to be repaired. How can this be accomplished?
5 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: My PHT150 SharpShooter is jammed
Here is a link to the instruction manual, with cleaning instructions that apply to clearing a jam. You may have to force the driver (or plunger) back in by firmly pressing on it with the edge of a flat head screwdrive or nail set or some such tool, being careful not to deform the end which drives the staple.
All it essentially offers is this:
SIMPLE TO LOAD
1. Press end clip in, then up.
2. Pull out spring assembly.
3. Load staples into channel.
4. Reinsert spring assembly and
snap end clip into place.
EASILY DISASSEMBLED
FOR CLEANING:
1. Squeeze stapling end of hammer
tacker together, taking care to
avoid sharp staple.
2. Remove locking pin.
3. Press end clip in, then up.
4. Pull out spring assembly.
5. Remove staple channel.
6.Clear and reassemble.
They are somewhat prone to jamming.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 07, 2011
SOURCE: heavy duty- professional hammer tacker
how to load
Posted on Jun 18, 2011
efs_perpends
  • 1996 Answers
SOURCE: I have a Stanley SharpShooter
Here is a copy of the instruction manual for your stapler.
EASILY DISASSEMBLED
FOR CLEANING:
avoid sharp staple.
Sometimes a bit of the staple material will be sheared off and jam the hammer in its guide, keeping the tool compressed. On the business end of a PHT150 there is a notch in the hammer housing and a slot on the staple carrier. Most times a standard screwdriver can be used by sticking the tip straight into the slot and using the notch to leverage the the two apart. If not, you can clamp the hammer housing in a vise and, using the screwdriver in the carrier slot, tap away from the hammer housing to release the jamb.
Posted on Sep 18, 2013
My Stanley PHT150 is jammed and I cannot remove the staple channel. The instructions do not address a jammed staple channel so, how does one remove it?
Hi Dave,
Nice and easy this one.... all you've got to do is remove the chrome coloured pin at the handle end. This then allows the magazine to be removed by pulling it from the front end. Just make sure that you've removed the pusher (Where you feed the staples in) from the back first
Sep 18, 2014 | Stanley PHT150C] SharpShooter Heavy Duty...
I have a Stanley SharpShooter PHT150 that's jammed. I would like a diagram/instruction sheet showing how to fix this problem. Thanks.
EASILY DISASSEMBLED
FOR CLEANING:
avoid sharp staple.
Jun 16, 2011 | Stanley Tools Hammer Staple/Tacker -...
My PHT150 SharpShooter is jammed and won't spring back. The staple plunger is sticking out and won't retract.
May 31, 2011 | Stanley Tools Hammer Staple/Tacker -...
Stanley light duty staple gun loads and shoots but staples not coming out. nothing jammed as far as I can see. Should I open it up and have a look at the interior? Thank you Denise
It sounds to me like you must have a staple that has seperated and probablygot stuck in staple feed shute' I wouold carefuflly remove side plate and see if there is a staple in there crooked or if their is is small metal chip left over from manufacture.I hope this helps you.THANK.
Apr 07, 2011 | Stanley TR40 Light Duty Tacker
The spring in Stanley TR45 light duty sharpshooter does not work, where can I get a new spring?
From what I have read, and I've searched, Stanley doesn't make parts for this staple gun. Only found hammer tacker springs.
Here is the phone number for Stanley customer service: 800-262-2161
It's a remote chance that one of those might fit.....
Hope this helps. If it does, please place a vote for me. Thanks,
Handie Andie
Apr 06, 2011 | Stanley Tr45 Sharpshooter Light Duty...
Stanley sharpshooter
Look at the above picture of the stapler and follow the bottom of it from the left side over to the right side. Right there on the end of it is a small piece of metal that looks bent down, bull this out and set your row of staples on top of the sled you pulled out and then slide it back it. it is ready to staple something.
Jul 14, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Oct 26, 2008 | Stanley Bostitch Pc2000 Staple Gun Tacker...
Stanley Tools Hammer Staple/Tacker - PHT150C Logo
669 people viewed this question
Top Stanley Hand Tools Experts
Jim Thurston
Jim Parker
Jim Parker
Ivan
Ivan
Level 1 Expert
Are you a Stanley Hand Tool Expert? Answer questions, earn points and help others
