Question about Philips Televison & Video
Philips SL92EAA SAYS LOCKED WHEN CONNECTED. HOW
Philips SL92EAA says 'LOCKED' when switched on. How do I unlock it as it has been in storage for several months
  • 566 Answers
Hi jgbaker
To answer your question;
The standard unlock codes when prompted to do so are; 0711 and 0712 for philips and magnavox tv`s
Note that you may have to do it twice.
Hope this help and good luck
By the way: is that model europeen ?
If so those codes may not work but it`s worth a try anyway.
Posted on May 27, 2010
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
I have a monitor philips 190S and the osd main control is locked. how i can unlock?
23 Oct 2008 ... There are a few things you can do to solve the problem, ... The menu should be reset and the flashing OSD control message should disappear. ... controls locked, then it comes up again saying OSD main controls unlocked. ... I have a Philips 190S monitor. I do have a button to enter the onscreen menu. ...
filetonic.com/blog/2008/10/23/osd-main-controls-blocked/
Dec 06, 2009 | Philips 190S7FB 19 inch LCD Monitor
Philips 170A7 locked OSD. How can i unlocke?
If the OSD is locked, press and hold the Menu button for 10-15 seconds to unlock the OSD
Oct 31, 2009 | Philips 190B6CB/27 19" LCD
Philips 28PW6006/05 locked after setting "NR" to Yes...
NR=Noise Reduction.
If set is locked you must use the parental code to unlock.
Aug 29, 2009 | Philips 28PW6006 28" TV
Philips magnavox tv, no remote....channels locked
I called Philips at 1 888 744 5477 and they solved my Access Code question thusly.
Default Code is 0711.
Hope I can submit this now, AND that it helps someone.
Jan 30, 2009 | Philips TP2784C TV
Philips monitor 190b6cb/175
Same problem OSD main controls locked the 5 seconds later OSD main controls unlocked then system closes down sayingproblem with atkdisp, what does all this mean? Can still operate my computer but thid damned flashing OSD message continues.
Aug 10, 2008 | Philips 150S4FB 15" LCD Monitor
Philips GoGear 2GB MP3/Video Player LOCKED ?
you have to look at the side and shift the lock button
Nov 26, 2007 | Philips GoGear HDD075/17 MP3 Player
Philips 109s20 crt monitor
Here's the link for the product support page; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=109S20&scy=us&slg=AEN&grp=PC_PRODUCTS_GR&cat=CRT_MONITORS_CA&sct=CRT_MONITORS_GT19_SU Click "User Manuals" on the left. or here is a direct link; http://www.p4c.philips.com/files/1/109s20/109s20_dfu_eng.pdf Check page 28: "The Main Menu displays OSD MAIN MENU LOCKED . Pressing the front control panels hasno effect. How can I unlock this function? Press and hold the OSD menu key for about 10 seconds until picture displays "OSD MAIN MENU UNLOCKED"" Hope this helps :)
Sep 03, 2007 | Philips Brilliance 109S Monitor
Televison & Video Logo
440 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
