Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60" HDTV Rear Proj NO POWER
Power is not coming on. HD cable box operating, Nothing from TV
  • jmsmith661 Apr 07, 2008
    Never gained contact with associate. Thanks for trying. Hope I don't get billed.
  • Philips Master
  • 8,617 Answers
Is the led flashing or just steady light? Also do you hear a click when you hit the power button?
Posted on Apr 07, 2008
  • Sonny Berry
    Sonny Berry Apr 07, 2008
    Contact them again they should credit your account I was trying to respond but it kept saying server error. I can try and help you by posting here. Does the power light come on? Does it blink? and do you hear a click when you press the power button
I need to know how to switch the TV to 1080. I'm trying to use a HD box
Connect you hd cable box to the hdmi input. If you don't have an hdmi input and have a DTV input you can get an HDMI to DTV adaptor. I hope this helps.
Mar 20, 2011 | Philips 60PP9202 60" Rear Projection...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
I have a DVR from Comcast hooked to the tv; what else is needed to view in HD. It is a Philips 60" projection HDTV (model 60pp9202) and how can I get a replacement owner's manual?
u need to ask ur cable provider what kine of service u have , not all cable boxes are hd , for ur owner manual just google , some may have this for free
Apr 13, 2010 | Philips 60PP9202 60" Rear Projection...
I have a sony 60 in rear proj. lcd that has no red in the picture other than faint red vertical lines all the way across about an inch apart. any ideas ?
It sounds like you do not have the red component cable firmly inserted. I had this problem on my first HD TV, when the green component cable popped out when I moved the TV back in place, and the picture was desaturated of any green, causing my wife to remark, "That sure doesn't look like HD..." I reinserted the green component cable, and the picture was excellent. Check those component cables.
Feb 06, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
I'm looking a HD cable.
This set may have a DTV cable. You probably have an HDMI cable on your box. You can get a DTV to HDMI adaptor.
Nov 23, 2009 | Philips 55PW9363 55" Rear Projection...
RCA Proj TV (model D52W14) Power light flashes 3 times
Replace CP150, CP120 and CP114. You can get the repair kit for your RCA at the following link. www.tvrepairworld.com the kit contains the capacitors and the CD with detailed instructions.
Sep 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need owner's manual
Click JVC Support to download owner's manual of HD-61FH97 TV
Apr 13, 2009 | JVC HD-61Z575 61" Rear Projection...
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
My hdtv component jacks will give a clear pic then pop back and forth into double images. Can anyone help?
Oct 03, 2007 | Philips 60PP9202 60" Rear Projection...
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
65 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
