Question about GE Tritonr XL GSD6260JCC Dishwasher
My ge profile dishwasher gsd5134 does not pump out all the water at the end of the cycle
SOURCE: nautilis ge dishwasher does not pump all water out aT THE END.
how do you fix it?
Posted on Nov 30, 2007
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
Posted on Apr 26, 2008
SOURCE: Will not drain
the selenoyd is bad take front bottom cover off you will see the problem selenoyd with 2 wires conected to it
Posted on May 03, 2008
  • 3422 Answers
SOURCE: GE Profile Dishwasher not draining
HI,
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Jul 29, 2008
gypsycat00
  • 224 Answers
SOURCE: GE profile dishwasher gsd5130d00ww does not pump
I believe this unit has an anti-siphon ball that is equipped to prevent back flow. Pull the dishwasher out and syphon the remaining water out. There is a large manilla colored hose that elbows from the back with a large hose clamp. Loosen the hose clamp and pull the hose free, you should see a little white ball come out. Put the hose back together, remove the spray arm (there is a plastic clip on the back, use a small screwdriver to pry it free but don't break it and a small 1/4" head screw for you to remove). Remove the two 1/4" screws from the food trap basket and remove the food trap basket. Drop the ball down the tube that is roughly the same size and reassemble the reverse of removal.
Posted on Jul 06, 2009
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
Hi, we have a GE profile dishwasher, and it is not draining. How do we fix it?
If you can hear the drain pump running but notice no water draining, you simply have a plugged or locked rotor on pump. If you do not hear the drain pump at cycle start (usually at end of wash cycle or when canceling wash cycle). Motor is dead. To access: First disconnect supply power and or breaker. remove access panel and disconnect hoses to input and output side of pump, now inspect and clear blockage or replace motor if dead.
Aug 19, 2010 | Dishwashers
Dishwasher stops running and won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
hhf
May 13, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Profile dishwasher not draining at end of cycle.
It would have helped if you provided the model no.
Check this GE website for possible causes. If you do not have the user manual then you can also download it from here, But you will need the model number. (should be etched on the body of the dishwasher)
http://www.geappliances.com/search/fast/infobase/10002419.htm
Dec 22, 2009 | Dishwashers
The pump on my GE Profile dishwasher is not draining.
If it is the last cycle only it is not the pump. It is a wiring or timer issue. Most likely the timer.
Nov 11, 2009 | GE Profile PDW8400J Built-in Dishwasher
WATER NOT FILLNG IN GE PROFILE DIHWASHER
It ended up being a simple fix. Soap had dried on the floater (water sensor device) and it could not move, therefore no water was going in. I poured hot water and vinegar into the washer and ran a complete cycle and it is working fine now
Jun 10, 2009 | GE 24 in. Profile PDW7880G Built-in...
GE profile dishwasher does not drain out aat end of cycle
I just fixed the very same problem by replacing the piston and nut (part # WD24X10018).
Jan 07, 2009 | GE Dishwashers
Nautilis ge dishwasher does not pump all water out aT THE END.
the fill valve may be contaminated with debris that makes it heavier so it floats lower in the water and tells the unit the water is gone when it's not.
Nov 25, 2007 | GE Nautilus 24" Built-in Dishwasher
GE Tritonr XL GSD6260JCC Dishwasher Logo
171 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
