Power will not stay on longer than 3 or 4 seconds
I have a Denon AVR 2016 which has been working great, suddenly now when I turn it on it clicks off and the stby button flashes red. Thanks
  • silence2 Apr 07, 2008
    Thanks Abrsvcs I'll give it a try.
  • 4,234 Answers
This unit is on protect mode meaning that a problem was detected in the final output stage. Try removing the speaker connections. If it still behaves the same way, the output transistors are most likely defective and will need to be replaced. The parts cost should be around $15-$25. Add in the local labor rate for the complete repair cost.
Dan
Posted on Apr 07, 2008
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
I bought a Denon AVR 791 receiver two months ago, work great, sound great with my Definitive Technology Speakers but 3 days ago while I was watching a movie on my PS3 the receiver turned off on the higher...
Clearly, it thinks you're overdriving it.
Blinking Power Indicator every 2 seconds means the internal temperature is high. (Page 76 of the manual)
Every half-second - speaker impedance too low.
Consider the load presented by the speakers and what their minimum impedance might be.
Check for loose speaker wires.
Feb 07, 2011 | Denon Audio Players & Recorders
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Aug 20, 2009 | Denon AVR-1908
Powers turns on then off
faulty power amp output section occurs this problem.
canyou open the cover and are you technicaly sound to do the repair.
nuwan.
Jan 19, 2009 | Denon AVR-1604 Receiver
Denon AVR-683 won't stay on
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Jul 24, 2008 | Denon AVR-683 Receiver
Power won't stay on
This could be a major problem in the power transistors or closely related. Recommend service by a technician
Apr 19, 2008 | Denon AVR-1507 Receiver
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
See: http://www.denon.ca/hapdfs/avr2105mane.pdf, page 72. In my case, the problem was a connector between my receiver and television. I unplugged it from my receiver and it now works.
Dec 03, 2006 | Denon AVR-2106 Receiver
113 people viewed this question
 Grubhead
Grubhead
