Question about Ionic Pro CA500 Air Purifier
How do you get it apart? really dirty insideand i don't want to snap it in to.
  • 36 Answers
Un-plug the unit,pull the top piece of plastic off and lay it on its back.While its on its back a little peice of plastic drops and allows you to slide the ionic parts back inside..Try cleaning with regular shop and water and cotton towel..
Posted on May 27, 2010
Can you add a prefilter to an oreck truman cell to grab the larger dust particles and decrease the zapping?a humidifier in the room helps but when the furnace is going it can still be often.
it should have a prefilter already on it. they have a screen looking filter that goes on the front of the cell. If you don't have one you need to get one. You should also have a charcoal filter on the back side of the cell, if not then you'll need to get one of those also, the charcoal is for odors and not for filtering dust. Putting any other type of filter in front of the cell will just be turning this into a filter type cleaner and will be defeating the purpose of the reusable Trueman cell. You may as well just buy a different cleaner if you don't mind buying new filters instead of cleaning the cell. I would recommend cleaning the cell every 2 weeks to keep it working properly. This will also keep it from snapping, if yours is snapping it's already too dirty and needs to be cleaned, if it's snapping right after it's cleaned then you have a plate that is arcing in the Trueman Cell, I have posted a fix for the ProSheild Models to stop the cell plates from arcing.
Feb 19, 2015 | Oreck Air Purifiers
Bearing on brush is hard to turn and smells like it's burning
bearing hard to move will put strain on the belt and burn it. the bearing is easily removable pull it off, sometimes its just a good clean it will need, if will not come off tape it off. remove the muck build up and give the bearing a good soak in some wd40 or oil and wipe off and check for good movement then replace the belt. as it will snap more easy now it has been heated up.
Mar 15, 2014 | Eureka The Boss Upright Vacuum Cleaner
How can i wash the engine from inside?
CRC makes a product available at your local store call "Fast Motor Flush". Just follow the instructions and the product will clean your engine fairly well. Really old and dirty engines may need 2 times.
Sep 24, 2013 | Hyundai Hynda Tiburon 2005othrYrs/Mds...
How to Clean electric motor in air purifier
replce the mtors as there is nothing in them to clean
May 23, 2017 | Air Purifiers
My air purifier dirty light keeps coming on, and the machine will not run, even though it has been repeatedly cleaned properly.
it obviously has a problem with the wiring. take it apart and make sure no exposed wires are crossing (wires without insulators) and make sure that none of the wires are disconnected
Jan 24, 2011 | Ionic Pro TURBO Air Purifier
My Oreck air filter makes a snapping sound every 5-10 minutes. I have cleaned it thoroughly and checked for wires but I can't see anything wrong. I even switched the air filters thinking that one room was...
Dont use when it does this. Your collection grate is dirty and the sound you hear is an electrical discharge arcing between the grates like a small bolt of lightning. That entire metal electrostatic grate needs to be cleaned with Orek's cleaner or something similar. But certainly do not use until you fix it.
Jan 11, 2011 | Oreck (AIRCOM1WOI) Air Purifier
Dear Expert, I do hear scary sound like a electric spark once in a while, and then stop. Should I turn off the switch? Thank you.
Arcing (snapping) seems too frequent
1. If the electronic cell(s) are wet from washing, turn the air cleaner off for two to
three hours.
2. Check the cell(s) for broken ionizer wires or bent plates. Repair if necessary.
3. Wash cell(s) and prefilter(s) if dirty.
Sep 28, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Ionic Breeze GP S1830 - makes a sizzeling noise
Funny you should post this when you did as I just finished reassembling my S1730.
Mine was making very loud noise, arcing violently, smoking slightly and would give a good shock when you touched the plastic covers(yes dirty plastic will conduct electric current).
1. Unplug the unit
2. Take the plastic covers off, front has four screws and back has snap at bottom, both slide up when loose.
3. Wash the plastic covers
4. take the light out and clean it with windex
5. Vacuum the inside, be careful of the two corona wires
6. Find the bead on each corona wire and while turning them slight so the edges scrapes the wire, move them back and forth to scrap the white power off the wires
7. scrape the cone shape plastic that the corona wires runs into, this build up is the primary culprit of the arcing which is the noise you hear. be careful of the corona wires again. I used an exacto knife and gently scraped it, sandpaper has been suggested elsewhere, once done scrapping, wipe down to clean any residue. The top cones are only part accessible, after cleaning mine the noise still persisted but acceptably lower than before. I think if you completely take apart the unit you can clean this cones better.
8. Reassembly is the same is opposite of disassembling.
Hopes this helps you.
Aug 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Snap and no power
I beleive your unit is overheating. this maybe due to build up on the air intake -rear of unit etc.
If there is no way to clean filters you may have to manually take it apart and remove dirt
Aug 12, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Cleaning
Finding any instructions on Google for this product line has been tough. Sharper images website is down as well. The main reason why there isn't anymore support for this product is because it has been proven by that ionizer don't clean the air and that the ozone created by them can be harmful to you. Due this information, Sharper Image has settle with consumers who own the product which has forced them into Chapter 11.
Here is a link about it
Jul 11, 2008 | Sharper Image Ionic Breeze® Quadra® Air...
Ionic Pro CA500 Air Purifier Logo
159 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
