Question about Ovens
F O illuminated on Dacor Oven keypad. Can't use oven
Dacor oven keypad illuminate "f o" in orange. all of the buttons work (bake, light, etc.) except for the up and down arrows. Can't bake anything as it is impossible to enter an oven temp. Same with changing time on clock...Suggestions?
  • 327 Answers
Hello,the igniter may look like its working but it may not be...when it lights the glow should be a brilliant yellow...if not and you have orange/yellow replace the igniter...
Thanks
Posted on May 28, 2010
Why does my oven reach temperature then fail to maintain it
For a more precise answer I need more information like is it light illuminates when the failure is occurred. If the light illuminates then is faulty oven thermostat. If the light does not illuminates then is faulty main temperature limiter.
Dado
Aug 04, 2014 | Electrolux EOB6630 Ultrafan Electric...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Regards,
BElectric
Dec 31, 2010 | Bosch Ovens
Bake element
It may have also Blown the Fuse, to the element, in the stove itself.
Feb 12, 2010 | Dacor ECD230 Epicure Electric Double Oven
Dacor 48" range, double oven. ovens do not work. Letters FO appear on the display. Any suggestions?
F0 means: Clock pushbutton is stuck in a depressed position. Check clock buttons. You might need a new touch pad.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Ovens
CPS227W Dacor double wall oven from 1995. Problem is common to both upper and lower ovens on any cooking mode (broil, bake, etc). Turn on, set temperature, hear a relay click on, then about 15 seconds...
I have the same problem, however I found that if I just hold the Bake, Broil.ect button in until you hear the relay click then the oven functions normally.
Sep 26, 2009 | Ovens
Display has very light illumination and does not display temperature or other settings. All functions seem to work but functions are not shown on display including temperature, Bake/Broil cycle, etc. Time...
This is a failure in the electronic range (or oven control) ERC or EOC. You can replace it with a new one, or have it repaired.
- www.fixyourboard.com
Jul 26, 2009 | Ovens
Control panel doesn't light up
HI, this issue concerns the touch pad(control board led). This will happen in certain models. it could be some minor corrosion within the wire contact clips that are not allowing the proper current to illuminate the led that is used to light the specific button or, it could be a minor circuit issue within the control board as well.
i recommend inspecting the control panels wire harness contact clips that are behind the actual control board. make sure they are not corroded or lose. if they are lose or corroded, i suggest replacing the entire wire harness. this could be the possible reason for some of the lights that are not illuminating during operations.
If the wires and contacts are in good condition and the harness is in good condition as well, this could be an internal control circuit board issue, concerning the LEd lights. they may have burned out due to the age or heavy usage.(heat related)..
Please rate and god bless:)
Apr 20, 2009 | Electrolux 30" Built-In Single Electric...
Convection Over with Dacor Millennia
We have the same issue anc alled Dacor. I seems as there is a problem with the oven as it was built with a faulty or missing temp control part. They have a fix for this problem by installing a temp control kit. you need to work through the warrantee group
Dec 20, 2007 | Dacor Millennia MOV130 Electric Single...
Ovens Logo
71 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
