Question about AMD Athlon 64 X2 4000+, 2.1 GHz (ADO4000DDBOX)
Vista...Running very slow
I recently upgraded to a compaq SR5123WM-B with a AMD Athlon 64 x2 4000+ Processor..  I also have 4 gigs of onboard memory.. Yes..  I know that while I am running a 32 mgz operating system I can only access 3.37 GBs of ram..
I also have 320 gb's of HD space..
Why does my old maching running xp and with a pentium 3 seem to run faster than my Vista??
Any way of speeding it up?
  • 1 more comment
  • Glenn Ponnath Apr 07, 2008
    Yes I have..  And I scan my system on a regular basis for virus's, adware and assorted bad guys..
    I also defrag my HD periodically..
    This system is so slow.  I am thinking I am going to have to switch back to XP
    yeah..  firefox was hogging alot of it..  400,000+ but I had closed that and its still running slow
  • Glenn Ponnath Apr 08, 2008
    yes...
    New Friend:
Vista problems like this offently happens because of viruses,spyware or registry problems. If <a rel='nofollow' href="http://www.improve-pc-tools.com/index.php/dealing-with-windows-vista-running-slow/">vista is running slow</a> you might wanna check for viruses in your PC first.
Posted on May 11, 2011
Every since I upgraded to Vista SP1, I have a periodic problem where, after 10 minutes of use, my machine runs so slow it is useless. For the first 10 minutes after a reboot, it runs normally. The problem is that none of my diagnostics finish before my computer goes into molasses mode.
Posted on Jun 10, 2008
    Guru:
  • 1,342 Answers
  • 1 more comment
  • Georgia B
    Georgia B Apr 07, 2008
    Have you monitored your system with Task Manager to see what is hogging all of your resources?
  • Georgia B
    Georgia B Apr 08, 2008
    Was it running slow before you updated to SP1?
    Read this
  • Georgia B
    I see your system came with GFX 6150 onboard graphics which means it uses system memory. A PCI-E graphics card may speed things up. And a 250w power supply which is a little weak 500w would be better.
    Also check in device manage to see if your drives are using DMA and not PIO.
    Check Services to see if you have Indexing enabled this is also a resource hog.
SOURCE:
Can i convert my Dell Inspiron 532 from 32 bit to 64 bit processing?
Windows will not install if you have more then 4GB of memory. Reconfigure the ram so it only has 4 GB and it should install.
Feb 17, 2015 | AMD Computers & Internet
I have an ET1161-05- can it be upgraded to hold more memory and run faster?
Hi.
Yes, your computer came with 2 gig's of ram in the form of 2 1gig modules of ddr2 ram.
There are 4 slots for memory all together, and each slot can hold 2 gig memory chips in each one, for a total of 8 gig's of ram!
That would cause a serious performance improvement for you.
It also came with a 160 gb hard drive, so if you want to, you can get as larger drive as well.
As far as processors, a dual core, AMD Athlon 64 X2 5600+ Brisbane 2.9GHz 2 x 512KB L2 Cache Socket AM2 65W processor will fit in with absolutely no bios updates required, so all you would have to do is take the old processor out, put the new one in, and turn the computer on.
It will recognize the new processor automatically, and will work right away!
This will have a significant performance boost, possibly doubling the total speed of your computer.
I hope this helps you out, and have a good day !
May 26, 2011 | E-Machines eMachines Desktop PC
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
Help Upgrading Processor
You'll find the information you seek at both the processor company and the motherboard company. As for remounting it in a Compaq case you may run into some issues of the On/Off Switch, power lead, reset button ect...matching up. You might be suprised at how inexpensive a new computer case is. I've seen some as low as $25. Your power supply can be removed and it will fit in your new case. You may just have a easier go of it. Good luck...please leave a rating, thank you kindly
Apr 25, 2009 | Computers & Internet
Upgrade Gateway AMD Athlon 64 Processor 3500+
friend
looks like your machine has two memory modules
1. 256 mb ddr 1
2. 128 mb ddr 1
module of 2 gb in ddr1 are hard to find
but all you can do is take out these two modules and replace with 2 x 1 gb ddr 1 modules
easy...
thanks
Apr 11, 2009 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Mar 22, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
AMD Athlon  64 X2 4000+, 2.1 GHz (ADO4000DDBOX) Logo
685 people viewed this question
Top AMD Computers & Internet Experts
Ekse
Alun Cox
Carlo Barzo
Carlo Barzo
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
