Question about Intermatic & Indoor/Outdoor Rain Tight Timer
I have an Intermatic Timer, Model R8806P101C for my irrigation system. I just replaced the timer itself because I could not get it to come on Automatically just Manually. I am still having this problem even after replacing the box. Can you tell me what the problem is?
protek480
  • 1714 Answers
SOURCE: Intermatic pool pump timer, time clock won't turn
Check your wiring, it sounds like it's not right. The clock needs 120 volts to run.
Posted on Jun 30, 2009
MOTORWIZJ
  • 1340 Answers
SOURCE: I have an Intermatic T101P201 120v pool timer. The
switch to malfunction YES HOMEDEPOT SELLS A ON OFF SCREW KIT CHEAP..VOTE..JAY
Posted on Jun 03, 2010
SOURCE: I have an Intermatic ET70115C
ET7015C manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et70115c%20-%20english.ashx
This particular timer allows Holiday settings that override regular settings.
Do a word search of the PDF manual for 'holiday' and 'HLDY' and it takes you to the pages that talk about holiday. For example page 8 talks about the Holiday (HLDY) feature
My strategy is to replace the out-of-sync fall-back and spring-forward days with holidays ... and then the holidays can be programmed to meet the correct buzzer time.
Now let me say something. I am not an expert on this particular timer. I wire and test timers, but I do not own this timer. And the manual is a pretty good slog of information. I have not read the whole manual, but you can add a comment and I am here to assist as you go along. I answer questions for free and am glad to help.
geno_3245_40.jpgSee this image at Imgur: http://imgur.com/rAXYx
The image on Fixya is too small to see the buttons clearly, but the timer lets you program up to 99 Holidays.
Fall-back is off by 14 days, and Spring-forward is off by 14 days, for a total of 28 days.
The manual says 'review and revise data' on page 12 thru 17
Posted on Nov 10, 2010
Testimonial: "This was a great idea. Thanks so much for your help!"
SOURCE: The timers on my Intermatic Timer T40003RT3 are
Sounds like clock motor(s) are working.
Snap mechanism out using thumb spring located inside top of box.
Look for clock motor number printed on clock, should be WG1573 for 240V timer
Google search for 'Intermatic WG1573'
For example Grainger sells that clock motor as 1PNK2
(plus they sell extra trippers which are designed to wear down):
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 05, 2011
HansPP
  • 2510 Answers
SOURCE: My timer (INTERMATIC R8806P101C) will
I don't know if this is going to be of any use to you but Retrevo have a manual to down load at http://www.retrevo.com/support/Intermatic-R8806P101C-manual/id/22966bh130/t/2/
Other suggestions are to remove the synchronous motor and check/replace that. It is the motor that drives the clock and can be ordered through irrigation outlets.
Posted on Apr 15, 2011
I have disconnected the internal wires from my Automatic Sprinkler Timer model R8806P 101C . and don't know where they are supposed to go. Is there a diagram of that? Specifically, where does the...
Thank you for including model number of product.
R8806P101C is 240Volt timer with 4 wiring terminals.
You removed factory wiring and want to reattach.
The on-off-auto switch does not have separate wiring diagram.
Intermatic offers tech support phone: 815-675-7000
Add a comment and say what you discover.
Open following links for resources:
http://www.intermatic.com/customer%20service.aspx
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8806p101c%20-%20english.ashx
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Aug 19, 2011 | Intermatic R8806P101C -...
What is the silver pin for in the packet model #R8806P101C
The silver pin is put into timer dial at 12 midnight to advance the day skipper wheel each time dial rotates.
Open following link for Intermatic sprinkler/irrigation timer resources:
Upvote the help.
And take advantage of fixya expert assistance live.
May 29, 2011 | Intermatic R8806P101C -...
I need to replace the toggle switch on an Intermatic Model: R8806P101C timer. Do you know the part number for the Carling Toggle Switch? ;
Open the following link for Intermatic parts:
Upvote the help.
May 24, 2011 | Intermatic R8806P101C -...
Hook up the system works when on but timer does not move there fore it will not come on or shut off automatic
If the yellow dial is not keeping time first check to see if the motor is wired correctly. If yellow dial is keeping time make sure you have the pins inserted correctly. see the parts list here.
Please see following link for parts list and Instructions
http://sbeelectricandhvac.com/doc_details/124-intermatic-model-r8806p101c-manual.html
May 23, 2011 | Intermatic R8806P101C -...
How to replace the R8806P101C timer?
Open following links for parts and manual.
http://waterheatertimer.org/pdf/r8806p101c-instruction-manual.pdf
1) You can buy replacement parts and fix old timer using part numbers shown on link above.
R8806P is 240Volt timer
2) If you buy new timer, insides of timer can be replaced without changing the box.
Snap out old timer mechanism using thumb spring located top inside timer.
3) When replacing wiring, take photo of wiring on old R8806P10 and then hook up new wires same way on new R8806P10. Wiring is as follows: 2 hot wires from breaker connect to far left terminal and terminal second from right. Load wires connect to other two terminals. Since this is 240V, the either color wire can connect.
Apr 16, 2011 | Intermatic R8806P101C -...
The clock does not move forward. If I manually turn it, then it will work and turn on the system where the pins are. I haven't tried anything to fix it because I don't know where to start. Intermactic...
Sprinkler and irrigation timers are 14 day.
Intermatic has a page with manuals:
Open page, click plus next to timers and scroll down to sprinkler and irrigation timers
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
It's good to have the manual on hand in case the product is discontinued
That being said, it sounds like the clock motor is bad.
Snap timer free from box and tip out to see clock motor located on back of timer.
Get the number off clock motor
Intermatic site shows pages of clock motors: They are priced high, but cheaper than new timer.
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Aplus supply sells assortment of Intermatic clock motors.
http://www.aplussupply.com/intermatic/timermotors.htm
To search these pages quickly for your clock numbers, use browser Find (Click edit at top of bowser, click Find)
Nov 08, 2010 | Intermatic R8806P101C -...
Sprinkler timer not keeping current time of day
Open following link for Intermatic sprinkler-timer parts list
If yellow dial is not keeping correct time, then clock motor has gone bad.
Replace clock motor.
Feb 28, 2010 | Intermatic R8806P101C -...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
78 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
