Question about Insignia 32" 720p Flat-Panel LCD HDTV
Television will not come on - Insignia 32" 720p Flat-Panel LCD HDTV
Is my powerboard serial number mlt668-LI is the same as the mainboard on my insignia tv?
Posted on Apr 06, 2011
    President:
  • 1,099 Answers
First check the AC plug of the television is properly connected to the mains power, if otherwise, it is require for you to open the back cover of the television to check for blown fuses , then if found replace with the same current rating...then if otherwise meaning that
Power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck...
Posted on May 27, 2010
I am asking for Sansui plasma TV codes pls!
The codes for a universal remote to work with a Sansui television are:
Sansui television remote code 834
Sansui television remote code 0310
Sansui television remote code 0394
Sansui television remote code 20695
Sansui Google Search
Dec 27, 2016 | Sansui Televison & Video
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    How to connect a philips antenna to a trutech tv
    Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    Hey there! Just replaced the lamp in my sony KDF70xbr950 and now it will not even come on I have 4 flashing red lights and then goes back to a solid red light can some one help!! ...
    The LAMP light is flashing or blinking.Solution
    If the LAMP light is flashing, first attempt to perform a power reset on the television. If this does not resolve the issue, then the lamp inside the LCD projection television may have burned out and will need to be replaced. If this appears to be the case, consult the Replacement Lamp Part Number table to determine the correct replacement lamp for use with your projection television.
    NOTE: The LAMP light is not the same as the POWER/STANDBY light.
    How to perform a power reset on a Sony® television.Solution
    Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.Unplug the television power cord from the electrical outlet. Let the television remain without power for 60 seconds.Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.Turn on the television.
    Sep 16, 2011 | Sony Grand WEGA KDF-70XBR950 70" Rear...
    When I turn on the TV the picture comes on for about 30sec. to 1 min. then the picture goes off and the standby light(green) flashes continuously for approx. 30sec and then the pictures comes back for...
    The problem with the television is that the lamp is bad and need to be replaced. This is as a result, of overheating inside the unit of the television. Be sure to have your television where there is proper vent.
    Try to unplug the television for a while before working on it as the television stores high voltage in it. Then you Turn to the back of the television, then you unscrew the television and assess the lamp of the television and replace it with a new one.
    Reassemble the television back together and power it on. That way it will work properly.
    Dec 31, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
    Keep always blinking the green lights indicator ones i plug the power cord. no video, no raster on the screen.
    The green lights on a Sharp television indicate a problem. The number of blinks is a code. The television has gone into a coma in order to protect itself. You can force this television on by doing this. Unplug the television. Hold down the vol+ and channel down button on the television and while holding them down still plug the television in. This is a temporary way to view the television but the problem will get worse if not repaired. Should the television power on this way unplug it when you want to turn it off without pressing the power button at all.
    Dec 09, 2010 | Sharp LC-32SB24U 32 in. LCD TV
    No picture
    If you are having sound but no picture on your television, the problem is the t-com board of the television.
    Once you have the t-com board replaced, your television will be in good condition once again. have a repairman replace the t-com board of your television and you television will be in good condition once again.
    Goodluck and take care
    Oct 10, 2010 | Sanyo DP42746 42 in. Plasma Television
    2003 Sony Trinitron 36" television. Just shut off, light blinkin
    The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
    If the issue is still unresolved after following all of the troubleshooting steps, Service will be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
    1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
    2. Unplug the television power cord from the electrical outlet.
    3. Let the television remain without power for 60 seconds.
    4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    Sep 14, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
    No picture or sound?? status light flashes in four blinking intervals. I was told it could possibly be the lamp it has never been replaced.
    The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
    1. Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
    4. Plug the power cord back into the electrical outlet.NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    Aug 08, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
    MY sony wega 40 inch won't turn on
    The STANDBY light is flashing on the television and there is no picture or sound. Solution
    sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
    If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
    Jan 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Insignia 32" 720p Flat-Panel LCD HDTV Logo
    132 people viewed this question
    Top Insignia Televison & Video Experts
    Jaime Hernandez
    Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
