Question about Kenmore Kitchen Ranges
Uneven Storage Drawer in Kenmore 940949 Range
We removed the storage drawer in our Kenmore 940949 range so that we could clean under the stove. The drawer fit perfectly before, but since we put it back, it is uneven, and doesn't slide shut smoothly as before. It does close all the way, but it sort of hangs up briefly just before it's completely closed.
As a consequence of the unevenness, our pans do not fit easily into the drawer
We did not force anything. When we removed the drawer, it came out easily. And when we put it back in, we made sure that the slides were in the track properly before closing it.
Of course there is no way to adjust anything on the drawer, and we are mystified as to why the drawer is now crooked.
Has anybody else had this problem? And is there anything we can do to fix it?
fridgetech
  • 473 Answers
SOURCE: uneven oven temp.
Check to make sure the bake element is coming on. If so try replacing the thermostat.
Posted on Oct 07, 2007
Illeagle
  • 525 Answers
SOURCE: The burners in the gas
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Yellow flame and black soot is an indicator that the flame tube is being starved for oxygen. Where the orifice injects the fuel at the base of the flame tube you should find a movable air adjustment shutter that is usually held in position by 1 screw. This screw may have loosened and allowed the shutter to close off oxygen to the flame. Below is a link to a page that shows an oven burner tube...click to enlarge image pn1015233 and observe bottom end. Rotate shutter any direction until a nice blue flame appears but is not "blowing" off the burner tube. Tighten screw to retain position.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1015233&PPStack=1
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
trav1856
  • 57 Answers
SOURCE: flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Posted on Dec 06, 2008
SOURCE: whirlpool electrice stove storage drawer
remove the drawer and put back the corret way , It is out of track.
SparkyNZ
  • 43 Answers
SOURCE: uneven oven temperature
It is possible that the thermostat on your oven needs calibration. However, major errors in temperature may be the result of a bad heating element or a door that doesn't close or seal properly, etc. Confirm that the oven is in otherwise good operating condition before attempting calibration.
Most thermostats have a calibration screw located under the knob. Try pulling the knob off and look at the shaft. Some shafts have a small screw located in the center. Rotating this screw will change the trip point at which the thermostat will turn on and off. This is determined by the sensor located inside the oven itself. Some other schemes allow for the entire control to rotate with respect to the scale. You will need to identify the type used on your oven.
Let me know if this helps.
John
Posted on May 09, 2009
I have a 1976 Gaffers & Sattlers slide in range I want to replace. Any idea how to remove it? Thanks
this taken from ehow site:
Slide-in ranges and freestanding ranges use the same installation techniques, with one minor difference: the slide-in range rests on the edge of your counter top. Removing a slide-in range is not difficult but will require a friend to assist. Removing the storage drawer from the slide-in range first will give you access to the power cord and gas shut-off valve, if your unit uses gas
Instructions
    • 1 Pull the bottom storage drawer out as far as it will slide. Lift up the front of the drawer and unhook the back of the drawer from the drawer guide. Pull the drawer away from the range.
    • 2 Reach under the slide-in range and unplug the power cord from the wall outlet. Turn the gas valve to the off position on the house line coming from the wall.
  • 3 Lift the top of the slide-in range with the assistance of your helper, and pull the range forward enough that you can access the back of the range.
  • 4 Go behind the range and locate the connection between the house gas line and the range gas line. Disconnect the flexible gas line from the house gas line with a pair of channel lock pliers or a pipe wrench.
  • 5 Lift up on the rear of the slide-in range while your partner lifts the front. Slide the range out of the cabinet opening and out of the house. Lifting the unit will prevent unnecessary damage to your counter tops.
  • Read more : http://www.ehow.com/how_5959888_remove-slide-range.html
    Jan 03, 2015 | Kitchen Ranges
    I cannot unlock the cooktop on my Kenmore gas range. There is no lockout button, only Select Clean and Stop/Clear. Neither one of which unlocked the cooktop. There is a little padlock looking symbol t
    I'm sorry, but the model number given in the question is either wrong or incomplete. Please check that model number. Usually, on Kenmore ranges, you can find the model # and serial # on either the left or right side of the storage or warmer drawer. Open the drawer and look on the frame of the range for a label. On a few ranges, the label is affixed to the frame between the oven door and the drawer.
    As an alternative, please post a clear picture of the control panel.
    Oct 20, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    How do I clean under the electric elements on my basic westinghouse stove
    Hello friend, thanks for your post!
    I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
    Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
    VF72824070
    Hello Anonymous, that's a great question!
    In order to provide you the correct cleaning instructions for your Frigidaire range, I would need your model number please. The serial tag, which lists your model number, is normally located in the storage drawer, on the right side. Thank you and I look forward to hearing from you. - Z
    Aug 30, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
    Storage drawer under oven is stuck with pans blocking it from opening
    Try rattling the drawer until you can slip at least part of your hand into it to begin shifting pans until you can start pulling them out/ If this doesn't work, turn off the power, and pull the range away from the wall. Make certain that the power is completely OFF. You may be able to reach the pans from the rear of the stove, but keep trying from the front. It is safer.
    Best regards, --W/D--
    Jan 25, 2011 | GE Profile JB968 Electric Kitchen Range
    My range top is not excatly level how do you level a glass top range?
    Most ranges have leveling legs. Remove the storage drawer and look to see if the legs have threads. Then twist a leg clockwise to raise one corner or counterclockwise to lower it. (It could be reversed - it's been awhile since I leveled a stove.) Adjust as needed to get the stove level front to back and side to side.
    BTW: the parts diagram for the 95002 chassis is here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-66595002100/0582/0124111/P0101022/00003?blt=06&prst=&shdMod= .
    I hope this helps.
    Jan 12, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
    Whirlpool electrice stove storage drawer
    There is a screw in the bottom of the two back corners that holds the drawer glide in place. Remove the glide and then you'll be able put it back the way it belongs.
    Nov 22, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
    Whirlpool range
    Hello dolphin 1 mom
    Welcome tofixya.
    You said, accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
    Send me your e-mail address and I'll e-mail the diagram with the door instructions for removal and replacement.
    It will not fit in here with the diagrams.
    Waiting for you.
    Huuum
    Please do not forget to enter a rating when we are done
    These are the installation instructions, but with no diagrams
    To Remove:
    1. Open the oven door. Insert door removal pins, included with
    your range, into both hinge hangers. Do not remove the pins
    while the door is removed from the range.
    2. Slowly close the door until it rests against the door removal
    pins.
    3. Grasp the door on the sides with your fingers on the front of
    the door and your thumbs on the inside surface.
    4. Pull door straight up, then toward you. Hinge hangers will
    slide out of front frame hinge slot. Do not remove door
    removal pins until the door is replaced on the range.
    To Replace:
    1. Grasp the door on the sides with your fingers on the front of
    the door and your thumbs on its inside surface.
    2. Hold oven door so that the top edge of each hinge hanger is
    horizontal. Insert hinge hangers into the front frame hinge
    slots.
    3. Tilt top of door toward range. Slide hinge hangers down onto
    front frame support pins. Make sure the hinge hangers are
    fully seated and engaged on the support pins.
    4. Insert the door stop clip with its angular surface at the top of
    the frame hinge slot, then push in the bottom of the clip until
    its flanges are flush with the front frame.
    5. Open the door completely and remove the door removal pins.
    Save door removal pins for future use.
    6. Close the door.
    StorageDrawer
    The storage drawer can be removed. Before removing, make sure
    drawer is cool and empty.
    To Remove:
    1. Pull the storage drawer straight back past the drawer stop
    notch and the end of the side rails.
    2. Lift up the back of the drawer and pull the drawer out.
    To Replace:
    1. Lift up the back of the drawer and place it inside the range in
    its fully forward position.
    2. Lift up the front of the drawer to a level position.
    3. Slowly push the drawer into the range until the drawer side
    rails engage with the gap in the drawer glides.
    4. Once the drawer is fully engaged on both sides, slide the
    drawer back into the closed position.
    NOTE: When removing and replacing the storage drawer, a slight
    push may be needed to move the drawer stop notch past the
    drawer glides.
    A. Removal pins
    B. Hinge hanger
    A. Hinge hanger
    B. Door frame hinge
    C. Support pins
    A
    B
    A
    B
    C
    A. Drawer stop notch
    B. End of side rail
    A. Engage drawer glide
    A B
    A
    Sep 09, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
    Jammed storage drawer
    svineyardWelcome to fixya.
    I'm Huuum and happy to assist you,
    You said, Y inherited a GE Spectra XL44 in the home I recently bought so you don't know much about it. There is a pan stuck in the storage drawer and You can only open the drawer about an inch and a half before it jams.
    You need two people.
    One strong person to slide the range forward, so he can tilt the range far enough back, that you can access the drawer from the bottom and the pan will fall back inside the drawer as you pull the drawer forward and out enough for you to reach the pan and turn it around or what ever you need to do to get it out!
    Bravo, I want to hear that you succeed!
    Be careful not to hurt your self.
    Bless You Huuum.
    Please do not forget to leave a rating when you are done.!!!!!!!!
    Aug 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Kitchen Ranges Logo
    61 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Mike Carew
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
