Question about Garden
Gilmour sprayer - model 020PEXG - need check valve - stamped on rubber valve ''mono valve'' ''151-400'' - where can I get them?
2 Suggested Answers
Biggdex35
  • 333 Answers
SOURCE: Weee killer leaks from my Gilmour sprayer finger
Im pretty sure that is all it is. The pressure is by how many times you pump it up. Its just on or off. Sounds like It needs to be cleaned real good, and put soap in it befor you put it bak together. Also there is a screen if you hold the handle and turn the trigger part and unscrew it.
Posted on May 11, 2010
Testimonial: "Thanks for the reply Bigdex!"
Model 030XPEG. Why won't sprayer pressurize?
Roundup 181538 Sprayer Parts Repair Kit : Lawn And Garden
www.amazon.com > ... > Sprayers
Amazon.com, Inc.Amazon.com : Roundup 181538 Sprayer Parts Repair Kit : Lawn And Garden ... Kit with Extension Wand and Adjustable Nozzle(Only for models 1991A, 1992A, .
Oct 08, 2015 | Gilmour Garden
Will not pressurize
Seals not sealing check cover rubber gasket and relief valve
Mar 05, 2014 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
How to fill gilmour spray-doc
All sprayers have a cap that turns anti-clockwise. With all of these you push the handle down and turn firmly.
Lawn Garden Gilmour Garden Watering
Mar 29, 2013 | Gilmour & Spray Doc& Poly Tank Sprayer...
Need to buy parts for gilmour backpack bp4. Where can I get them?
Got the same sprayer, can't get parts. Toss it in the trash like I did, don't buy anymore Gilmour products.
Aug 01, 2011 | Gilmour Bp4 4.5 Gallon Back Pack Sprayer
How do yo get the sprayer to actually spray there is no pump to build the pressure to let the spray out. Is there instructions to the sprayer I have missed placed mine if there was some in the box
Here is the web site link for your sprayers manufacture. on the bottom rt is the model you can choose yours and get the manual you need. as you know there is usually some way to pressurize the tank, either hand pump or air pump. This should help and if you need more help please contact me. Thank you http://www.gilmour.com/tips-tricks/
Jul 13, 2011 | Gilmour Garden
My gilmour wheelpump sprayer just quit spraying. It appears to not be building up pressure. I have cleaned out the valve and screen on the bottom, removed and rinsed out the hollow oval 'ball'...
Your pump cam follower may be broken, such that the pump is just not working. It happened on mine. You don't need to buy any parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmore provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business.
See photos at:
http://s911.photobucket.com/albums/ac317/vonoretn/Gilmore%20Wheelpump%20sprayer/
May 11, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
When I pump up the Green Thumb two gallon sprayer, air escapes from the top in the center by the pump handle. Also why must I add oil to the holes in the top?
You add oil in the two holes to lubricate the seals around the pump shaft. Maybe the seals have dried up now and that is why the air leaks by.
May 26, 2010 | Gilmour No 2pgt Green Thumb 2 Gal Ld Tank...
May 10, 2010 | Gilmour 1 Gallon Lawn & Garden Spray Tank...
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
