Question about HP OfficeJet 7310 All-In-One InkJet Printer
Crooked copies Faxes and copies are printing crooked.
  • Azraphael May 27, 2010
    Can you check the paper guides in the paper tray are holding the paper straight? That could be your problem I have had that happen to me when the paper was not alligned in the tray and it printed crooked
  • 903 Answers
Tighten the fences and guides that hold the paper in place. If the paper is not snug in the tray, it will not pull through straight.
Posted on May 28, 2010
Printing copies crooked
prints ok from a different tray????????????????????
Feb 14, 2014 | Konica Minolta Bizhub C224 Color Copier /...
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
HOW CAN I REPRINT COPIES OF RECEIVED FAXES .
once it has been printed or the m/c has been disconnected there is no way of printing the faxes again..Sorry!!
Nov 17, 2009 | Canon FAXPHONE L80 Laser
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
Printing crooked from one drawer, and no option to print from another drawer
Try this spray on a little WD40 on the GLASS and wipe it off.
Yes, you heard me correctly, make sure you wipe it off leaving no residue, but it's still slippery.
the problem may be coming from the glass being too dry and the paper is getting stuckand shifting.
If the paper itself was going crooked it would get jammed or ripped. There is no room for the paper to go through the path crooked so the only way for it to copy crooked is somewhere in the optics.
try doing 1-2 on the glass itself and see if it copies crooked.
The envelope tray is a By-pass tray and can be used for any size paper.You can switch which tray it copies from on the panel tray button.
Aug 28, 2008 | Canon imageRUNNER 2200
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
2nd side crooked
I would have to say that there must be a same piece of paper touching the paper as it is being feed through the duplex ass'y. The best thing to do is to see if the copy gets tilted toward the front or rear of the copy/ copier. You will be able to find where the obstruction is in the dupex path.
Feb 23, 2008 | Canon D320 imageCLASS Digital Copier
HP OfficeJet 7310 All-In-One InkJet Printer Logo
144 people viewed this question
Seeker5211
Seeker5211
