Question about Euro-Pro EP621 Bagless Upright Vacuum
Shark Euro-pro EP621 Bagless Upright Vacuum. Q regarding the brush not spinning / after troubleshooting and taking actions listed below, it now spinning for a few secs, but then stopping. Already removed hair, strings, etc. Checked that belt is aligned properly, checked that small wheel that turns belt is working (spins fine when belt removed. Oiled the turning parts a bit, that made it spin better, but still stops. It turns about 3-4 seconds then stops. If I switch it off and on again, I get again 3-4 seconds, then stops. Off - on - 3-4 secs, stops.
5 Suggested Answers
  • 42 Answers
SOURCE: Shark euro-pro x upright vacuum that shuts down every 15 minutes
These are prone to overheating. The manufacturer put a foam 'filter' wrap around the electric motor. This filter wrap insulates the motor, trapping heat inside, which causes overheating. The motor is very similar in form and function to the one in the Hoover Windtunnel, but the Windtunnel has no filter wrap. It doesn't overheat, and functions fine without it. There is a filter on the intake anyway. It's a redundant filter, and I have removed mine. It works fine now.
If you take the filter out yourself, you will need a special screwdriver for one of the motor cover screws. I guess they don't want the consumers opening it up.
I suggest taking it to a vacuum repair shop and explaining to them the problem, and asking them to remove the filter wrap from the motor.
Posted on Feb 23, 2010
SOURCE: Shark Pursuit Euro-pro X vacuum cleaner, 12 amp, upright model
This vacum cleaner is equipped for auto shut off when it gets hot , It gets hot when it gets clogged either the little sponge filter is to dirty or the the round white filter in the dust collecting container.
But if they are both clean then it is clogged in the line probably with lot of carpet fiber, in that case you ned to take the dust container out and possibly the assembly from bottom like when you change the belt, then take of the Handle where the flex hose is attached, then you gonna need a wire hanger bend a long shape close to the shape of the hose line from handle to where it curved around in the bottom opening where it collects the dust behind the spin brush the just stick the hanger from the handle side cause the clog is probably in the lower side then just push the clogs out . Be care full not to puncture the flex hose with hanger. Its probably a good idea to bent the tip of the hanger so that it wont poke hole in the flex hose.
That's what happened with mine I spend hours and hours and days to figure it out. I could have just through it away, but it just kind a pissed me off and the War was on as stubborn as i am, but finally I won and I got the satisfaction of the sweet victory.
Waste lot of time though but it just one of those things. It never messed with me again.
But that is what's wrong with it. Good luck it a good vacum though very power full.
Posted on Apr 17, 2011
  • 23 Answers
SOURCE: how do you attach the attachments on the Bagless
put them on the end of the hose
Posted on May 31, 2011
  • 506 Answers
SOURCE: Is there a manual available
Here is your manual
Posted on Jul 18, 2011
Why wont the roller brush turn on my navigator shark NV22L
It could be a bad switch or brush roll motor, a broken belt, loose wire or contact. You must inspect and test all these areas to narrow down the cause.
Feb 28, 2017 | Euro-Pro NV22 Shark Navigator Bagless...
There is no suction on spin brush
-Broken belt or some thing stuck inside. Check it out and remove or replace.
Good luck
Apr 25, 2015 | Euro-Pro NV22 Shark Navigator Bagless...
How do I remove brush from the NV-22 Shark Navigator Bagless Upright Vacuum?
Remove the screws from the power nozzle and the cover can be removed to get to the brush
Oct 11, 2013 | Euro-Pro NV22 Shark Navigator Bagless...
Why did the beater brush stop working? how do i fix it?
check the belt it sounds like its broke take the bottom off where the brush is and there should b a belt that drives the brush
Jan 21, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
Need new brush
Here is a tip that I wrote about how to find the parts you need for your Shark
How to Find Shark Parts and Accessories
Nov 02, 2010 | Euro-Pro NV22 Shark Navigator Bagless...
Need new brush ( power beater bar) and belts
You're in luck! We carry both the belts, as well as the roller brush for your Shark Infinity model that you listed this repair under.
Here are links to both parts you are requesting:
Euro-Pro Shark Infinity NV30, NV31 Bagless Upright Roller Brush Assembly
Belt Set For Shark Infinity Bagless Uprights, Models NV30, NV31
After you receive the parts, here's a link to the manual that will walk you through, step by step on how to replace both items if you have any questions, or need help:
Shark Infinity Bagless Upright Owners Manual
Hopefully this was able to answer your questions. Please feel free to reply to this email or just give me a call if you have any further questions. If this helped, please be so kind and rate the repair, or leave some feedback for me.
Chris Jones
May 22, 2010 | Euro-Pro NV31 Infinity Vacuum
I need a new roller bar or beater brush for infinity vacuum
Hi There,
Here's a link to that part on our website if you haven't found it already:
Also if you need belts for this machine, here's another link to the belts on our website:
Euro-Pro Shark Replacement Belt Set For Shark Infinity Upright Models, Part 1085F
I hope that this information helped you. If it did, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand corner of the repair.
Thanks again,
Chris J.
Apr 14, 2010 | Euro-Pro NV31 Infinity Vacuum
My euro pro shark steam mop is leaking a brown liquid that smells like plastic and coffee. is it breaking down inside?
No, but the water gets crappy from the minerals left behind when it steams....
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
Nov 24, 2009 | Euro-Pro Shark Professional Upright Vacuum...
Euro Pro Model S1209 12 Amp bagless vacuum
Checking the switch and cord would be the 1st thing to check. Is there a reset near the bottom on the back? If there is one, just push it in and see if it starts. Could also be a bad motor.
Feb 10, 2008 | Euro-Pro EP621 Bagless Upright Vacuum
Euro-Pro EP621 Bagless Upright Vacuum Logo
60 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
