Question about Onkyo TX-SR606 Receiver
Won't turn on. I've had this problem before and know there is a simple process to reset but I can't remember it. Thanks.
    President:
  • 1,099 Answers
you can do this by pressing and holding VCR 1 button and then push power button, it will reset and turn on.
Hope this will help...
Posted on May 27, 2010
We don't remember the code please help with the axample
You must be having the manual override keys. Just open the safe with those keys and reset the passcode.
Jul 14, 2014 | Safe International Digital Electronic Safe...
Lights are on but car won't start there is a loud ticking sound but the car won't turn over
replace your battery. seriously i know it sounds simple but sometimes, thats all it is. just a simple fix. trust me i've built hotrods and spilt blood sweat and tears just to lay under the damned thing in the middle of the night and have a brain storm. and to realize that i just needed to stop and think simple, would have saved me days of aggravation, and tears! just try it. cadillacs are especially touchy. so always start simple.
Oct 07, 2011 | 2001 Cadillac Eldorado
1995 geo tracker won't start. I've replaced everything except the ignition switch. It used to click when i turn the key, now it won't even click.
DISCONNECT YOUR BATTERY AND RECONNECT, THIS SHOULD RESET THE BRAIN.
ALSO...WHEN YOU TURN THE KEY, LISTEN TO HEAR IF YOU CAN HEAR THE FUEL PUMP COME ON...IF NOT, GUESS WHAT? HOPEFULLY NOT!... BUT,YOU MAY NEED TO REPLACE THE FUEL PUMP, IF YOU CAN'T HEAR IT WHEN YOU TURN THE KEY, AFTER YOU'VE RESET THE BATTERY!
HOPE THIS HELPS!
Aug 30, 2011 | Geo Tracker Cars & Trucks
Have f11 fault tried to reset and machine starts up, turns a few times, then gives a strange noise then f11 appears and pump starts draining, had f11 few years back and was fuse but remember at this time...
sounds like you've either got a stiff motor or gunk in the drum making it difficult for the motor to turn. When the fuse blows the drum won't turn at all but as yours is trying to turn then throwing the fault up it sounds like something is causing too much resistance
Aug 26, 2011 | Dyson Flowcheck CRO1 Front Load Washer
DON'T KNOW WHAT D-LINK IS. I'VE BEEN TRYING TO CHANGE BOTH MY USERNAME AND PASSWORD, AS THE FORMER SEEMED TOO PERSONAL AND THE PASSWORD WOULD AT ONE TIME GO THRU, THEN SPORADICALLY, UNTIL NOW IT...
Sounds like the D-Link is failing. Here is what you can do.
First grab a pen and push the reset button on the back of the router (hold it for 5secs)
Next follow the link below to change your username and password. If you cant find the D-Link CD dont panic, simply continue following the instructions for additional info.
Here is the link
http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Aug 11, 2011 | D-Link DIR-615 Wireless Router
I have a sony KV-30HS420 CRT HD television whose menu keeps flashing on and off. I'm not sitting on a remote anywhere, and I've disabled all the signals in the house that I think might be...
Hi
Get the set to reset fist and see whether it helps you. To reset it do the folloing:
1 Press POWER to turn on the TV
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
If this process does not solve the proble of your TV, its memory IC has damaged. Memory IC is one which holds the data we enter to the TV set, and the processed is stored. It is a nn volatile memory [the memory stored in it won't get lost even power is switeced OFF]; which holds all the data in. The data stored in it will retrive to main system processing IC each time we switch ON the TV set. This is an eight terminal IC, very samll one indeed, can be located very near to the main system control IC, at system control section. It can be repalced. This IC can be bought from most of the electronic spare part shops at your town. It is very cheap to buy. Even though it is very small and cheap one, its function in TV circuit is great. Almost all the functions data is stored in it each time we operate the system. It will have a specific number printed on it, and should be noted when buy a new one. Insist on that number, substitutions or an other number won't even switch ON your TV. OK.
Jul 15, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Onkyo TX-SR606 Receiver Logo
174 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
