Question about Kenmore HE2 Plus Front Load Washer
F-21 after putting the F-21 keeps poping up and my washer stops washing...
  • 5,911 Answers
"F21" is a Long Drain error code. This is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can also often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are both very simple repairs that you can perform yourself without the assistance of a repairman.
NOTE: For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back with your complete MODEL NUMBER. I hope you find this information helpful.
Posted on May 28, 2010
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
My whirlpool cabrio washer model# WTW7600XW0 is saying F error code?
NEED TO KNOW F WHAT F51 IS THE RPM SENSOR ON THE MOTOR ARE YOU MAY HAVE CLOTHING STUCK IN SIDE THE WASHER THE BASKET WILL SPIN REAL EASY BY HAND IF NOTHING IS STUCK IN THERE ARE IF YOU ARE GETTING F1 YOU NEED A NEW MAIN CONTROL BOARD
Oct 29, 2012 | Whirlpool Washing Machines
The washer I have is a whirlpool, duet sport washer and for some reason it keeps stopping at F-21. That is whgat is flashing across the display window and it woon't go any futher than that at all. Any...
you have to remove the bottom lower panel(unplug washer first), get some towels,unscrew the pump screen at the bottom right(may need to use pliers to unscrew), clean screen and put it back. WITH DRY HANDS!!! plug cord and test washer. if good replace lower panel. F21 is a Drain took too long fault.
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool front loading washing machine and when I try to do a load of laundry, it will wash, but then flashes an F21 error message....and stops......I have tried canceling the load and restarting...
The F-21 code is a blocked drain tube. Take off the front lower panel and locate the drain. Should be front right, Disconnect it and clean out the little trap that collects stuff. Put back together and should be fine. I always find stuff like coins and tissues wadded in there. It made for collecting foreign matter to keep the drain clear.
Jan 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops with an F-21 notice. Somehing wrong
drainage pump inside washer is broken. Most likely some debris buildup around pump. Mine just did the same thing a couple of days ago. new pump cost about $126.00
Aug 10, 2009 | Washing Machines
My Washer flashes F 21
Your filter is probably clogged. Unplug the washer and remove the lower front panel (three hex screws). You may need to tip the washer back to do this - be sure to have someone hold the washer while you work. The filter is about 3 inches in diameter and unscrews from an assembly just to the left of the pump, which is on the right side of the washer. It is hard to turn, but with a little muscle it will unscrew. Be prepared for water to gush out. It can be a lot or a little depending on how much water is left in the tub. Once unscrewed, clean out all the junk that has accumulated in it. Make sure the the pump rotated freely and doesn't have any obstructions. Then screw the filter back in and put the panel back on. Assuming you found a lot of junk inthe filter, this should solve your problem. Good luck.
Mar 18, 2009 | Kenmore 46462 Front Load Washer
Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
