Question about Sony Playstation 3 (PS3) Console
NETWORK ISSUES LOSS CONNECTION TO PS NETWORK, CAN'T READ IP ADDRESS. IT WAS DOING JUST FINE
    Problem Solver:
  • 18 Answers
You may need to clear the harddrive or it may be an internal malfunction
Posted on May 28, 2010
Laptop wont connect to wireless network but desktop is fine.
Perhaps, it just needed a new IP address. Simply rebooting the computer and resetting the IP Address of the computer took care of the issue.
or
That sounds like symptoms of Manufacturer & Windows drivers conflicting. Try uninstall the Manufacturer Drivers and let the windows ones do the work, and see how that goes down.
Apr 20, 2010 | HP Mini 1000 Netbook
Playstation network failed internet connection
There is a worldwide issue which Sony are fully aware of which is affecting
all old model PS3's, The new slimline PS3's are not affected.
Due to an internal clock failure on the units they are not syncronsing with the
network time on the PSN's end. Causing error-8001050F
There is no official ETA although at 16:58 GMT today (1st March) Sony released a
statement stating they should have the problem resolved within 24 hours and have
advised all PS3 users experiencing issues NOT to use their PS3 until they
advise the issue is resolved as it could result in loss of functionality and
further damage.
For up to date informaton see:
http://uk.playstation.com/games-media/news/articles/detail/item266689/PlayStation-Network-currently-unavailable/
http://community.eu.playstation.com/t5/PlayStation-Network/PSN-Connection-issues-error-8001050F/td-p/10303803
Many thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
Ps3 wont connect to wireless
Reset your router, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Thanks
Sep 02, 2009 | Sony PlayStation¬ģ 3 (60 GB) Console
Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Mar 12, 2009 | Xerox Phaser 8500/DN Printer
I cant connect just one network
Be sure that your wireless network is working
Check your wireless router settings
Check if you see any other wireless network available on your computer
Test connection, see if you pulled an IP address
Go to the Windows desktop
Select Start then Run
In the text box type: cmd (WIN98/SE type command)
At the command prompt type: ipconfig
4. What does it read as the IP address?
* If it reads 192.168. something dot something then you are pulling
an IP address and are connected to the network. The problem is
software related, check your firewall, and wireless card configuration.
Also check any WPA or WEP encryption keys. Check with the respective
manufactures.
* If it reads 0.0.0.0 for the IP address you are not connected to the network.
* Check your connection configuration and the adaptor.
* Check with the respective manufactures.
STEP TWO/ Basic troubleshooting continued....Testing the adaptor
1. Go to Windows desktop
2. Select Start then Run
3. In the text box type: cmd (WIN98/SE type command)
A DOS window will open.
4. At the prompt type: ping 127.0.0.1 (reserved IP address for all adaptors)
5. Check the line that reads "packets sent = 4, Received = 4, Lost = 0
A. Zero is good, the adaptor is working. Again check the connection
configuration,and the adaptor configuration.
It may be a power issue especially with older or less expensive computers
or wireless cards.
* Check the antenna location, are you inside or outside, look for interference.
B. If it reads all 4 packets lost, the adaptor is not functioning.
* Check and update the drivers, Contact the respective manufactures.
* If it shows any number of packets lost (you are dropping packets)
it is an adaptor or signal strength issue (generally form the laptop side,
not being able to reach back) especially with older or less expensive
computers or wireless cards.
* Update the drivers
* Check antenna location, or distance from the signal
* Contact the respective manufactures.
Nov 14, 2008 | Gateway (802.11usb) Wireless Adapter
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Belkin Parallel AutoSwitch F1U115E
Please advise of further info. All the connected PC's are running on XP. One is not connecting to the network. Sounds like the "Local Area Network" setting needs to be set for "Automatically assign an IP". Go to the start menu, select "Run" and type in "CMD". Type "IPCONFIG" and enter. This will display your network setting and IP address. If there is no IP address, then you will enever have a connection. If the IP address is listed, it will display a unique IP address, a subnet of 255.255.255.0 and the ip address of the gateway. Please respond with any further.
Jan 24, 2007 | Belkin F1U115E Parallel Switch
Sony Playstation 3 (PS3) Console Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
