Question about Ingersoll Rand Air Impact Wrench 1/2in. Drive, 4 CFM, 9500 RPM, 1200 BPM
My air impact runs without squeezing the trigger.
When i hook up the air to the 3/4" model 261 air impact it runs without squeezing the trigger. help?
  • 50 Answers
If u take the tail outa ur gun u will see that da gause filter inside has broke up.it gone inside and holding da valve open pick it out wit a seal pick r somethin
Posted on Aug 03, 2010
Repair wrench
This should help identify Parts for your zinger doll Rand #261 Air Impact Wrench...
Look here:
http://www.atecsarl.com/wp-content/uploads/2013/08/271.pdf
Apr 17, 2014 | Ingersoll Rand 3/4" Drive Super Duty Air...
Ingersoll Rand 2100G air impact wrench turns when air is hooked up. I can stop it by hand and then use it with the trigger, and it works fine, but it continues to run even when I let the trigger go. What...
The I.R. 2100G shares parts with the 2135 series impact, the throttle valve seal on these models have a tendency to wear out or deteriorate casing the throttle valve to by pass air. On the model 2100G the parts in question is only sold as an assembly (item# 22).
But you can disassemble the inlet bushing and install an inlet parts kit p/n 2135-K303, it includes all the necessary parts.
I will provide to links for you to look at
2100G: http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45667599_ed2.pdf
2135Ti : http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
The I.R. parts list shows the inlet bushing in detail.
Oct 28, 2011 | Ingersoll Rand Air Tools & Compressors
I have model 261 3/4 in drive impact gun. When in tighten mode it doesn't work all the time. It does work and then it doesn't, all you hear is air.
Air motors have plastic fins in them that make it turn. They slide in and out of slots on the motor. You can tear it apart and clean them, but if you don't put all parts back in just right, gun will not work at all. I usually try to run wd-40 thru the gun. It is messy, but the more the better. You can also use carb cleaner (brake cleaner will eat paint, rubber, anything pastic) and then oil with air tool oil. Careful of the cleaner it is flammable!
Feb 24, 2011 | Ingersoll Rand - Rand IR - 252 3/4'' Heavy...
I have a husky impact wrench, set at 100psi, but all that happens when i squeeze the trigger is air comes out of three vents on the bottom of the wrench, just adjacent to the imput hose. Is there something...
get some air tool oil and put it in the hose connection and manually turn the socket end by hand,the air vanes have frozen in place and can't hold the air in to operate the unit,make sure when you do this squeeze thge trigger to let the oil into the units barrel,then connect to an air supply and try it,you may need to help get it started by hand,then let it run and add some more air tool oil again to keep it lubed
Jan 27, 2011 | Impact Husky® 1/2" Wrench
Hi, The socket adapter spins before i engage trigger
The seal is bad inside leaking air pressure to the gun without squeezing the triger. Get a reseal kit from Sears
Jan 22, 2010 | Craftsman Tools 1/2" Air Impact Wrench...
My Aircat 1404BG impact gun stopped working.
most of the problems accure from being dry try 2 or 3 drops through the air intake fitting every so often depening how much you use your air tools, it may be time for a new one but i would try the air tool oil first before bying a new one, i hope i helped.
Jan 02, 2010 | Impact Aircat AC1603 3/4" 1330 Ft - Lbs...
Willnotingnitereddyheater model t12
hope it's just lack of oil, oil impact wrench prior to each use. Use air tool oil and pour in where you attatch hose, hold trigger in so that it goes inside. About 1 tablespoon, without oil torque of impact wrench will diminish to nothing. Hope this helps
Jan 01, 2010 | Air Tools & Compressors
IR 261 air wrench vanes sticking
NOT exactly a solution, but may help you with your problem: I'm also a Owner of a 261 ( In fact 90% 0f all my Air Tools are IR) that I used everyday when I was working on Terex Equipment & EMD Locomotives. I "Upgraded" the Major Parts inside my Gun to the "Industrial Line" rather than the Automotive Parts since the 261 is classified as a Automotive Tool..and Installing an Adjustable Regulator on the Gun Helped a Lot too...by "tweeking" my Gun out, I was Pumping almost as much torque as some of the 1" Guns...
FYI: Don't Over Oil as the Oil will absorb into the Vanes, causing them to Expand in thickness "Permanently"...just 2-3 drops of a Hi-Grade Air Tool Oil before starting the Day is enough...sounds to me like your Picking up some contamination someplace??
Feb 05, 2009 | Ingersoll Rand 3/4" Super Duty Extended...
Ingersoll 261 problem
that tool is under warrenty whoever u bought it from should have it fixed. did u try to adjust the air flow on your forard and reverse by turning the nob right or left has numbers on it hold the trigger turn the nob i see what it does i rebuilt many a 261
Feb 01, 2009 | Ingersoll Rand 3/4" Super Duty Extended...
Ingersoll Rand Air Impact Wrench 1/2in. Drive, 4 CFM, 9500 RPM, 1200 BPM Logo
528 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
