Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP Officejet 7410 prints OK, but copy and fax comes out black all but 1 inch
When I make a copy or send a fax with my 7410, the top one inch of the document comes out fine, but the rest of the page is black. The unit still works fine as a printer, but this problem has rendered it useless as a copier and fax machine. Any help or suggestions would be greatly appreciated as I spent $500 on this machine only 2 years ago. Naturally, it is out of warranty.
Thank you,
Jeff
Strange that it completes the first inch fine, can you perform scans to the computer fine?
You may be able to fix this issue by unplugging the unit while it is on and holding the # and 6 while plugging the unit back in (semi full NVM reset)
Posted on Apr 15, 2008
The problem is on the scanner...
You have to change "scanner assembly". But... here in Greece this unit has not spare parts.... The repair procedure is "unit exchange". You have to contact HP Service in order to inform you if they can change only the scanner assembly and not whole unit... You can call telephone support.
Posted on Apr 11, 2008
Im trying to get it to print copies only blanks so far
You can make multiple copies by loading them print side up into the upper feeder you'd use to fax, then entering the number of copies on the keypad and hitt the copy button for color or black
or you may lift up the carriage and place a page on the scanner glass, close the carriage select the number of copies and hit the copy button for color or black
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Office Jet 7410 printer copies, fax are black
If you make a copy and it is black, either the ccd (reader is bad or the lamp is out) either is the end. Take it back to staples if you can.
Make sure you unplug it for about 1 hour and plug back in and try a copy.
Apr 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 6310 wont copy or fax from top loader. To send a multipage fax I have to send each page separately
When you slide the pages into the top loader you reach a small plastic tab and probably stop there. Push pages in another 1/2 inch or so and you should hear a beep indicating the paper now is in far enough.
Dec 05, 2008 | HP Officejet 6310 All-In-One InkJet...
Blue line vertical on all color copy and scans...help does not receive fax
turn off unit and unplug from power source for at least five minutes.
reconnect to power source and turn it on.
disconnect the phone from the printer.
printer must be directly connected to the wall jack.
Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
Nov 21, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Unable to send a fax
Is your fax correctly plug in the outlet line of the wall and the same in the back of your fax....????
Mar 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Good, so u are having probs in ADF. Open the cover, lift the rollers and u can see the scanning glass. Take a lint free cloth and clean it. it will be ok.
Feb 03, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP7410 Print Problem
http://h10061.www1.hp.com/ccsearch/search?cc=us&lc=en&dlc=en&sni=391194&opname=HP+Officejet+7410+All-in-One&pname=HP+Officejet+7410+All-in-One
copy and paste the above link into your address bar and search for the answers.
Nov 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
90 people viewed this question
Seeker5211
Seeker5211
