Question about IBM ThinkVision L170 17" LCD Monitor
Monitor in power saving mode, can't turn on computer., what is power saving mode
  • 11,361 Answers
You may have power supply problem in the monitor (90% of the LCD monitor failures are due to bad caps in the power supply).
Try it on another PC, also check all the pins on the VGA cable. If it still does not work and you want to DIY repair, the plase read below;
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 28, 2010
How do i turn off power save mode using the screen buttons
I don't know if there is a monitor with a function button to turn off the power save mode.
As far as I know the power save mode of the monitor can be found in the display setting of the windows..
Anyway... If you want to turn off the power save mode of the monitor via windows display setting then here is what you need to do:
On control panel, double click display settings.. click the screen saver tab... on the lower portion Press the "power" button.. Select power schemes tab.. Change the settings of" turn the monitor off" to "never"
Click apply and then OK..
Hope it gave you an idea..
Much appreciated if you rate this help...thanks..
Uncheck the box
May 19, 2010 | Dell E173FP 17" LCD Monitor
Monitor goes into power saving mode when turned on. Doesn't go on when mouse is moved.
It's not on power saving mode, it does not sense that it's already is plugged at your VGA.
The only thing to test it out is to have another monitor/computer *to see which one is not working
But I'm pretty sure that it's a computer problem, Probably a VGA driver problem or a motherboard.
The best way to trace is to have another monitor/computer.
Feb 15, 2010 | Computers & Internet
Every time i turn on my daewo monitor it saying "POWER SAVING MODE' then turn off power auto.
Hi this means your Monitor is in power saving mode , it is trying to save power when you dont use it, Change your power saving settings and it will work perfectly
Thanks
Dec 28, 2009 | Computers & Internet
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Dell Monitor in Power Save mode
Hello there:
i would refer to your users manual to see if there is a power save mode setting on the monitor it'self and to see how to adjust it or contact the manufacture of the monitor . ok ?
hope that this is helpful
Aug 06, 2009 | Dell E173FP 17" LCD Monitor
Power saving mode
Prevent the laptop/desktop monitor from going to power saving mode:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 04, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
    How do we turn off the POWER SAVING MODE on the monitor screen?
    Try going into your Start Menu then going into your control panel...then clicking on your "power options"....then switching the options to 'always on'..if this does not work..(as it seems you may not be seeing this because the monitor is in power saving mode) try fiddling with the setup option on your monitor and find a possible powersaving mode enabled function and disable it. every monitor is different so I couldn't really help you here...if this doesn't yield results try another monitor to see if it's the monitor having the problems or the computers video card...the video card could very well be the culprit...
    Apr 08, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
    My Gateway 500s monitor is stuck in power save mode
    Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
    1r1sh
    A+
    Net+
    MCP
    Jan 24, 2009 | Gateway 506GR PC Desktop
    In power save mode
    The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
    Nov 17, 2008 | Dell E173FP 17" LCD Monitor
    Monitor
    -Turn off both computer and monitor
    -unplug monitor from computer(still plugged into power supply)
    -turn on computer and monitor(monitor is still unplugged)
    -After computer is on for about 30 sec. plug monitor into computer
    -turn off both monitor and computer(now connected together)
    -turn on monitor then computer and should be good to go!!!
    Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
    IBM ThinkVision L170 17" LCD Monitor Logo
    820 people viewed this question
    Top IBM Computers & Internet Experts
    Computer Links
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
