Question about Compaq Presario CQ60-220US PC Laptop
Plastic tubing over hinges
Because of laptop (Compaq Presario CQ60 WM419)not closing properly the plastic tube (is cracking)thats over the hings need replacing also. I can't find the name of this piece, so that i can order it. Thank you for your assistance.
  • 553 Answers
Go to your manufactures web site, choose "support".
http://www.compaq.com/country/index.html
It may take a little searching but you should be able to find what you need and order the part on the same site.
Or you can call: (800) 888-0220
Posted on May 28, 2010
Hings is loose on compaq presario cq60
If you remove the screen surround and then the base of the machine, you can then access the hinges and tighten the screws.
See utube for disassembly instructions;
http://www.youtube.com/watch?v=2VJctK-ugwU
Hope that helps.
Dec 23, 2013 | Compaq Computers & Internet
It looks like the hinge assembly has cracked on one side - solutions anyone?
Here is where to order a new hinge
http://lcd-hinge.ecrater.com/p/13973872/compaq-presario-cq50-110us-hinge
Sep 11, 2012 | HP Compaq Presario CQ50-110US Laptop
"Compaq Presario CQ60-209tu inbuilt microphone
Hi, You may have to take apart the laptop to find the connection problem. In many cases it will be in the hinge. If you are not the fixing type brimg it to a PC shop. Good Luck.
Oct 02, 2011 | Compaq Presario 700 470024-192 Notebook
How to remove the screen of compaq presario cqm60
Basically the LCD screen is attached to the bottom of the laptop by the hinges. This may require the keyboard to be removed to get access to the LCD connector to the motherboard. The hinges may also be secured by screws at the back of the laptop.
Oct 01, 2010 | Compaq Presario CQ60-220US PC Laptop
Lcd hinges cracked
The parts you're looking for are called "display panel hinges" You can buy these parts from compaq/hp directly, but personally, I would call, find out the part number and try to find a cheaper place to purchase them. A detailed video on removing the LCD panel completely can be found here. This will show you how to remove the broken hinges, and on the left side of the page, you can select videos that will show you how to do practically everything else. To get your replacement parts go to the compaq website (I couldn't find the part without the serial) or call 1-800-227-8164. There is also a live chat option once you go to the support section of the website. You may be able to rig the display so it works without buying a part, but now that you have the information, it's up to you. I hope this helps!
Jul 14, 2009 | HP Compaq Presario V5201us Notebook
Removing the LCD from a Compaq CQ60-215DX
I have a CQ60-220US HP Compaq and access to the LCD screen was different than others I have disassembled and replaced the display. The bezel is snapped on, the lid does not lay back flat to access the two hinge screws, but there are 2 screws with rubber covers down by the hinges, not all the way around.
I used a right angle phillips screw driver and was able to remove the bottom screws, popped off the bezel the remainder of the way around the screen, it is different, but don't be fooled there are a few screws just not the amount you might be used to, and then gaining access to one of the hinge screws on each side can be an issue as the lid did not lay back flat, but with a good right angle screw driver you can get it done, I did. I am not sure if the proper method is to not just remove the entire top cover and hinges, but the right angle screw driver and finding that this model had only a couple bezel screws made it much easier to tackle.
Jun 16, 2009 | Compaq CQ60-215DX Notebook
Compaq presario 1200
there are plastic covers over the hinges, which may be part of the faceplate. being a compaq the hinge screws are most likely torx head screws. compaq used to make a special tool for removing the plastic covers on their laptops. the tool was a bar with a piece of fiberglas circuit board embedded in it. you insert the circuit board into the groove between the top and bottom covers and twist. this is, of course after removing all of the cover screws. some of the cover screws on the display may be hidden under rubber bumpers.
Jun 28, 2006 | Compaq Presario 1200XL104 Notebook
Compaq Presario CQ60-220US PC Laptop Logo
125 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
