Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I need a good part number for my jd 2020 starter 4 cyl gas
  • 66 Answers
Is it direct drive or gear? We carry both...your talking 157.97 plus S&H for Direct and 235.90 plus 60.00 core fee and then S&H for gear drive...both delco starters. ediesinc@gmail.com for more info.
Posted on May 30, 2010
I have a 1965 0r 66 1020 3 cyl gas engine. It
I have a JD 3 cylinder gas 1520 that had a very similar sounding problem. Turned out to be a clogged fuel filter inside the connection of the fuel line to the carb. An old time JD mechanic fixed it for me the first time and I have since cleaned it again after a dry dusty mowing season. I hope this helps.
Jul 13, 2010 | John Deere Tractor 1020, 1520, 1530,...
Engine turns over and getting fuel, put has no spark on JD 322
check for cracks in the spark plug wire it sounds like it is shortening out or a ground wire.
Mar 01, 2010 | John Deere &Reg Branded 27" Tractor Metal...
What tools do i need to take out a starter
LE, is that the f or 6 cyl?'
I just changed my starter (cyl) with a socket set. Only two nuts to remove if I remember... a very easy job.
The 4 cyl is even easier. Installation instructions come with the replacement starter.
About $100.
Dec 02, 2009 | 2006 Chrysler PT Cruiser
I have a JD 2020 1970. The brakes lock up when I
sounds to me like the caliper/piston/cylinder is freezing up on it
try looking at replacement
Oct 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I have a 2020 jd it over heats after about 1 hr work radator is clear?
that radiator is not in the best place ,wash it out real good it usally has hydo leaks that drips on the radiator then collects dirt
Jun 29, 2009 | John Deere Tractor Side Screen...
Clutch problem
Hello:
It Sounds like the Clutch Idler is Bent and Requires Replacing.
A Homeowner can Replace the Clutch Idler Arm and Pulley with Little to No Worries.
You can View a Breakdown of this Unit at the Following Site Addy.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Enter the Model Numbers 2020 and CLick Search. Now Select your Model and then Select Sectional Index.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
1989 tempo 2.3 4 cyl 5 speed, runs w/ starter fluid
Hi, The carb is gummed up from sitting. The best solution is to take it apart and clean it. The starter fluid indicates that it has clogged jets or stuck floats. The good news is that if it cranks with the starter fluid everything else is probably OK. Good Luck!
Feb 09, 2009 | 1989 Ford Tempo
2005 Escape starter replacement
take the negative side off the battery put the car on ramps secure the rear end so it does not roll and if you need a diagram for removing and installing the starter try autozone
Jan 17, 2009 | 2005 Ford Escape
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
66 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
