Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
LE code error
We've removed the front panel and there isn't a broken wire. We've also shut the power off at the breaker and turned it back on. Still nothing.
    Sergeant:
  • 380 Answers
LE error code is a wash motor problem. The motor could be bad and it's known for wires to become corroded in this. Double check those wires. Pull the whole casing off and inspect every wire. Especially the red and purple wires. towards the bottom, by the big plastic casing is most common spot.
Posted on May 27, 2010
I have an LG wm2277hs washer, started to flash LE code now it will not power up
Le error is a motor error code. The motor error could be caused by several things including : motor, bearings , rps sensor and wiring and in some cases all. continued use with this error could have taken out your mother board.
Dec 13, 2015 | LG Washing Machines
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
I get an LE error message on my LG Dishwasher. I replaced the pump. Still get the LE error. Replaced the main control. Still get the LE. No blockage in the pump. What now?
When you receive the LE error code, unplug the machine for approximately 15 - 20 minutes. This will reset the microprocessor.
Oversudsing is the main cause of LE error codes. Using non-HE detergents or too much detergent will cause stress on the motor. Oversudsing can also cause leaking and odor.
A breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire.
A couple of notes about this - there are at least three motors on this unit - the main pump, the drain pump, and the 'vario motor' which appears to control the direction of water flow through the sprayers. The main pump is the one likely to go bad. Another cause of the LE code is broken wires in the door. The wires in the door get stuck in the black sound insulation and eventually break. Sometimes, this causes the LE error code. Check the wires in the door first. They are located behind the large front panel. It's easily removed by undoing 6 screws.
Sep 06, 2010 | Dishwashers
Why is my dishwasher flashing LE
This is very common problem with LG dishwashers. The LE error code (locked engine) is not allways indicative of a motor problem.
Simply unscrew the front door panel from the retaining screws on the inside of the perimiter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thouroghly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape and you're back in buisiness!
Jul 08, 2010 | LG Dishwashers
LE error message
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Good Luck!!
Dec 11, 2009 | LG Dishwashers
LG Front load washer LE error
Here is a link to the service manual for your washer...
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Check page 18 for error code LE which is 'locked motor' There are several causes, the manual will help you determine the cause. If you're not comfortable taking the thing apart, call your appliance repair man...
Oct 11, 2009 | LG WM-2277HW Front Load Washer
LG modèele LDF78105T error code LE
(Just copy and past the above link in your web browser)
Good Luck!!
Aug 15, 2008 | LG Dishwashers
There is an error code that says LE
Thanks for using FixYa!!
Jul 27, 2008 | Dishwashers
Model No- LD-12AW2 LE Error showing what does this mean
LE error code means that there is a problem with the motor.  One thing to check is to remove the front door panel and check the wiring harness to see if there are any broken wires.  If there is, repair the wire connections and see if the dishwasher returns to normal.  If not, then the motor assembly will need to be replaced.
Apr 20, 2008 | LG 24 in. LD-12BW5 Free-standing...
LE CODE
This problem started to occur for me about a week ago in about the same way as others have indicated, AND about 16 months beyond the expiration of the warranty. This CANNOT be a concidence. What a tick off! Also, the 800 number "help"line is a joke.At this point I am about ready to file a class action lawsuit, or at the least bad mouth this product to whomever, in or out of the media, will listen. Can I get an AMEN?
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
97 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
