Question about HP Laserjet Cp2025n Printer
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
  • 223 Answers
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
Posted on Jul 13, 2010
HP Colorlaser CP2025dn PCL XL error Subsystem: KERNEL Error: IllegalOperatorSequence Operator: BeginPage Position: 14 Printer worked fine until I bought a new computer. Installed fine. ...
This seems like a driver issue to me. Are you using the Universal, PCL5 or 6, or PS driver?
If using PCL and are getting this error, try the Universal HP driver from the website. Likewise, if you are using the universal, try the PCL6 device specific driver.
If this fails, let me know and I can assist further
Jun 19, 2009 | HP LaserJet P2015 Printer
Pcl xl error kernel illegal tag 0xlb 6 HP 3050
Re install the driver for the printer or the best thing is format the system
Jun 19, 2009 | HP LaserJet 3030 All-In-One Printer
Printing problems
GO ON LINE AND TYPE IN THE FOLLOWING INFORMATION.
EXCEL ERROR PCL XL ERROR
ENTER
LASERJET ERROR KERNEL ILLEGAL OPERATORS SEQUENCE ENDCHAR POSITION 293
ENTER
CALL THE MANUFACTURES CUSTOMER SERVICE LINE AND ASK FOR TECHN SUPPORT AND GET THE RIGHT ANSWER TO THIS COMPLEX QUESTION PLEASE
ROD GANDY
Jan 22, 2009 | HP LaserJet 4250n Printer
PCL XL error
Please uninstall the current PCL driver and upgrade the same with UPD PCL5 (dont install PCL6) from http://www.hp.com/go/upd
Regards,
Nikhil
Dec 16, 2008 | HP LaserJet 1320n Printer
Printing error
when i send for print i et
PCL XL error
subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Posittion: 7
Jun 15, 2008 | HP LaserJet 6p Printer
Printing problem "PCL XL error"
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
May 29, 2008 | HP LaserJet 1320n Printer
Printer error
Hi there guys reinstall the driver using PCL 5e as the program you are using may not understand the PCL 6 newer driver. Try this
Hope it helps
Thanks J
Nov 14, 2007 | HP Color LaserJet 3500 Printer
HP Laserjet Cp2025n Printer Logo
4,941 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
