Question about GE Energy Star PDS22SIS Stainless Steel Bottom Freezer Refrigerator
Very hot at front between freezer and fridge freezer not freezing
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezervery hot at front between freezer and fridge - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 03, 2010
On my Hotpoint FFA90 fridge freezer occasional leaks occur at the bottom of the freezer where ice accumulates. The fridge section above is fine. Any suggestions?
There is one in the freezer section as well. It's a small white tube. I've had the same thing happen with mine. I just took everything out of the freezer, and used hot water. It's caused by condensation buildup in the drain tube, which then freezes, obviously because it is a freezer after all. Hot water usually does the trick. Just be sure to clean it up, and dry it off really well so it doesn't re-freeze and cause the same issue.
Aug 26, 2016 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint mistral plus
Sounds like a faulty thermostat, although fast freeze usually bypasses the stat so should then get to temperature. If the compressor and condenser are getting very hot and all is clean, check there isn't a condenser fan stuck underneath that is seized. If not, may have had a bit of a refrigerant leak and sucked a bit of air into the system. Call an engineer
May 19, 2012 | Washing Machines
Hi at the back of my fridge freezer i think the compressor at the bottom is very hot, also the small pipes at the back is not heating as much as the compressor, actually anything but hot but not cold...
It possibly needs re gassing. Call a refridgeration expert in to look at it for you, there is nothing you can do without the gas bottles and evacuator.
Hope that helps.
Jan 04, 2011 | Microwave Ovens
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Side by side. Front edge of divider between fridg
There is a heater there that reduces condensation. If you have a switch that has energy saver mode, that would turn it off
Sep 04, 2009 | Refrigerators
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fridge has hot spot
Hit it with a big stick!
Mar 24, 2008 | Refrigerators
GE Energy Star PDS22SIS Stainless Steel Bottom Freezer Refrigerator Logo
94 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
