Question about Dell 924 All-in-One InkJet Printer
The holder for the ink cartridge is broken. Do I
The holder for the ink cartridge is broken. Do I need to buy a new printer or can I
get a replacement hold?
  • 96 Answers
Buy a kodak for 99.00 and the ink is under 5 dollars
Posted on May 28, 2010
My Phaser 6125 printer has broken part in the cartridge holder and now the color ink cartridge cannot be taken out of the printer, can I fix this problem (DIY)
The toner holders are each sold separately, the part numbers are 604k44920, 604k44930, 604k44940, and 604k44950.
http://www.iteminconline.com/604k44920_604k44920-xerox-6125-holder-k.htm
Jan 02, 2016 | Xerox Phaser 6125 Laser Printer
Tip
How to replace a brother catridge.
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the cartridges is empty or near empty, the printer will tell you to replace that ink cartridge.
You can buy the cartridges individually, or you can buy a pack of all three color cartridges or a pack of two black cartridges. To replace one of the ink cartridges, follow the steps below.
All four of the cartridges are located on the right front side of the printer, behind a gray plastic cover. Pull the cover forward from the side, where there is a slight cutout for your finger to grab. When the cover falls forward, you'll see the four ink cartridge holders, coded by color.
For the ink cartridge that you need to replace, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop out toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right, they go black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once the cartridge is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place.
If you are replacing more than one color, repeat this procedure for each cartridge. Then, when you are finished, close the ink cartridge cover.
If you were out of ink or low on ink, the machine should recognize the new cartridge and perform the calibration process. If it doesn't automatically recognize the new cartridge, it will ask if you have changed one or more of the cartridges. Press "1" for Yes when it asks about a color that you replaced, or "2" for No if it asks about a color you didn't replace.
Once the printer comes back up to the ready state, print a color test page to verify that everything is working. If the test page comes out okay, the new cartridge is fine and you can either discard the old cartridge in the trash or save it to recycle. (But don't get rid of it before you are sure that the new cartridge is recognized and working correctly.)
on Jul 21, 2010 | Office Equipment & Supplies
I have a broken ink cartridge holder on a lexmark 730 series.it is saying ink cartridge missing
Hi David,
Unless you have a very expensive printer or you know of a store that has a wide range of used printers, it won't be worth your time and money to order a new cartridge tray for your printer.
I would suggest buying a new 730 series printer and keeping the old one for spares.
If however you're curious as to the price of a new cartridge holder it would be your best bet to browse to www.lexmark.com and do a parts enquiry from the website.
Best wishes,
Graemevm
Jan 14, 2012 | Lexmark Office Equipment & Supplies
Keep saying ink holders have not been inserted correctly
Try using Canon factory new cartridges.
Canon does not support or allow the use of OEM cartridges on their products.
On the real bad side, you may just have voided any type of warranty claim from Canon.
Go back to the place you bought the cartridges and tell them their product damaged your printer and they need to fix it.
May 20, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I need to change the ink cartridges on epson stylus sx200 but i need help as instruction book doesntreally tellyou how-thanks
buy an ink cartridge made specifically for your printer. Turn on your printer and raise the lid or press the cartridge changing button. 3 Wait for the cartridge carrier to slide out. with an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. with an Epson printer close the cartridge holder lid and press the cleaning button to charge the cartridge. Close printer cover.
Dec 09, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Black cartridge is not being recognized, amber light blinking
Nov 10, 2008 | HP Officejet 7210 All-In-One InkJet...
How do I install a new cartridge holder?
Click this link for a service manual free download for your multipass c2500 inkjet printer troubleshooting.
This will help you replace the holder.
If you cannot click just copy and paste the following link into your browser window.
http://www.nodevice.com/search.html
Apr 30, 2008 | Canon MultiPASS C2500 InkJet Printer
Black ink won't print
Any tape/plastic left on the contact points on the cartridge, or any dirt on the contact points on the cartridge or cartridge holder? Will your old cartridge work, except poor print due to empty of ink? If so your new cartridge may be broken.
See if you can try a cartridge known to work in your printer and also try your cartridge in a printer similar to yours to eliminate source of error.
Mar 13, 2008 | HP DeskJet 3930 InkJet Printer
The color ink in my hp deskjet 920c won't work
try cleaning the contacts (bronze like) with dry cloth both the cartridge and the cartridge holder most of the times there exist some liquid forms on both areas. since you frequently remove the cartridges; their might be a broken part on the cartridge holder. the broken part, use, is to make sure the cartridge is in absolute contact with the cartridge holder's. the size the said broken part is 2 mm in all sides. so small that it has a big function.you dnt even recognize.
Nov 07, 2006 | HP DeskJet 920c InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
373 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
