Question about SanDisk Sansa Clip MP3 Player
I click on the music folder and nothing's there. This is a macintosh computer
  • 820 Answers
To see music in the music folder on your computer, change to MSC in USB mode in the player from:
Main Menu > Settings > USB mode
For firmware FW 1.01.11 and below on the Sansa Clip the selection for USB mode switching is not available: For adding this selection update the firmware of the player.
You could also force the player into MSC mode using switches/buttons on the player.
0. Player not connected to the computer.
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the center button while connecting the device to the PC.
When using iTunes, the player should also be in MSC mode. How to transfer music with iTunes on a MAC computer:
http://kb.sandisk.com/app/answers/detail/a_id/1141
Posted on May 27, 2010
Tip
Coby MP-705: Adding music, film, data - Macintosh OS X
Macintosh OS X
Open a finder window. Located the files you would like to transfer from your computer.
Select the files/folders with the mouse and press APPLE-C (copy) on the keyboard.
Click on the Removable Disk icon located on the left side of the finder window.
The computer will display all files and folders currently stored in the player.
Press APPLE-V (paste) on the keyboard to transfer the files you selected in Step 1 to the player.
on Dec 30, 2009 | Coby MP-705 Digital Media Player
Sansa 2.0 gb mp3 player having trouble getting it to
I had the same problem when I connected to the computer. So I used my friends Labtop definite 2.0 usb. Did you try to update your sansa click on link and download install run connect sansa when asked.
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
this has the manual also Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa ) easier not to sync
I hope this works
Apr 19, 2009 | SanDisk Sansa E280 MP3 Player
Installation for philips gogear using apple macintosh
Can't. But, you can simply plug in the gogear into a mac USB port and manually drag music into the MUSIC folder. Files must go into that folder for player to recognize them.
Other than that, software only available for PC.
Apr 08, 2009 | Philips GoGear Flash MP3 Player
Playlists & thousand songs dissappeared from itunes
if you synch it yes it will wipe it out - you can get software to back your ipod back to your computer so I would personally delete all the play lists and re do it. your music will be in my documents --> music --> itunes so you can re add it that way and re sort the playlists.
If its on mac os then it will be under your music folder ( macintosh hd --> users --> your username --> music --> iTunes
It may be that your itunes library file may have gotten corrupted so once you have gotten it sorted out close down itunes and go back into your music folder and itunes folder and make a backup copy of your itunes library files.
Assuming your not moving your music files around in side of the music or itunes folder it should be fine.
Mar 14, 2009 | Apple iTunes
"How do I make my AppleTV accept other videos than those download
You have to add your videos into iTunes for them to be visible to the ATV.
Mar 11, 2009 | Apple TV MB189LL/A 160GB RTL 160 GB USB...
Printer Won't Print
Step one: Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu. Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: Check the product cable, Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds. Reconnect the USB cable to the product and computer.
(NOTE: The product must be connected directly to the computer using a USB cable or a powered USB hub. If the product is connected to the computer through a non-powered USB hub, or if the type of hub is unknown, connect the product directly to the computer) after the product is connected to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step.
Step three: Determine whether the product is paused or offline, Click Start and click Printers and Faxes. The Printers and Faxes window appears. In the Printers and Faxes window, right-click the product icon and click Open. The Printers folder opens. On the menu bar, click Printer. Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it. If the menu includes Use Printer Online, click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: Stop the print queue, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder; Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs. (NOTE: If the queue was accidentally stopped, the print job will resume automatically. If the issue continues, proceed to the next step)
Step five: Delete the print jobs, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder, Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue, Click Start Jobs, Double-click the appropriate product in the product list to open the print queue.
When the print queue is empty, click Start Jobs. Try the print job again. If the issue continues, proceed to the next step.
Step six: Remove and re-add the product to the printer list, Double-click Macintosh HD, Double-click the Application/Utilities folder, Open the Print Setup Utility folder, Select the appropriate product.
Click the red X to delete the product from the computer, Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer, after the computer is restarted, double-click Macintosh HD.
Double-click the Application/Utilities folder, Open the Print Setup Utility folder, and Reconnect the USB or Ethernet cable to the product. If the product is not automatically added, click Add. Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 18, 2008 | HP DeskJet 5150 InkJet Printer
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click OK.
Step two: - Check the product cable
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
If the menu includes Use Printer Online , click that option.
Step four: - Stop the print queue
Double-click Macintosh HD.
Open the Print Setup Utility folder.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
Step six: - Remove and re-add the product to the printer list
Click the red X to delete the product from the computer.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 - NOT PRINTING - only scanning
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 12, 2008 | HP DeskJet F380 All-In-One Printer
I cannot print but i can scan
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 09, 2008 | HP DeskJet F380 All-In-One Printer
SanDisk Sansa Clip MP3 Player Logo
154 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
