Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Compacitors for 52525
I have found 12 compacitors the 4 on the dm board and 8 on the other 2 circuit boards. Should I replace them all. The 4 on the dm board do not look swollen. It sounds maybe just to replace the 2 on power supply board but I find 4 that are in a cluster. Which ones should I replace
    President:
  • 3,130 Answers
All of them.
Posted on Apr 08, 2008
What causes sound to be low on my tv I have to have sound turned up to 60 65 Where my identical tv is on 26.
check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Nov 16, 2016 | Televison & Video
LG PG PLASMA tv powers up has sound but no picture. Just put in a used new power board old one had blown compacitors. TV has no flas codes just no picture
with the tv on through one of the openings shine a light in the hole to see if it is just the back light or the screen driver. check this first then come back with the result.
Mar 18, 2014 | Eclipse E7703AVX DVD/CD decks
How to replace the dm in wd-52525
The DM is the second board inside the Chassis block directly underneath the FMT board. But replacement DM boards if still good are very expensive your better off replacing the 4 capacitors that fail on the DM.
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Green timer light no picture
Also known as the Green Blinking Light of Death.
The repair on this is cheap but very time consuming and wit no gaurentees.
There are 4 Capacitors on the DM board and 4 Capacitors on the Formatter board that are more than likely defective and need to be replaced.
On the DM board the locations are C81A2, C81A3, C81B3 and C81B4. They will probably be swollen.
On the Formatter board the locations are C8F19, C8F21, C8F22 and C8F27. Also will probably be swollen. The values of all 8 capacitors are the same. 1000MF/16V. Replace with value 680MF/16V.
While you have the chassi ripped apart, check the power supply board as well. You should fine some swolle caps on it also. Replace with same value of the one you remove.
Now once all of this is done and you put everything back togeather, you have a 50/50 chance of success. I have found that many surface mount caps can also go bad on the formatter board. If your repair does not work, then replace all of the surface mount caps on the formater board that are 10 and 16 volts.
Good luck to you.
Mar 19, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Green light(timer0 is blinking for last 12 hours . no picture . screen is totally dark
this means the DM board is not booting up. You will typically need 4-8 capacitors to fix this issue. you have to pull out the board and solder in new parts. let me know if you feel skilled enough to do this and I can give directions. The caps will usually bulge at the tops and are 1000uf .. mitsubishi recommends replacing with 680uf 16v caps..
if you do not want to repair yourself, a repair center can ship the chassis in for rebuild, total repair about 400 or 500 $
May 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Missing power supply
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 21, 2010 | Hisense TL1700 17 in. LCD Television
Blinking Green Light
check ur dm board it could have caps as well
Dec 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mits 52525 blinking green light
Good Day;
If you only changed 4 caps,1000 ucfd 35v, it should be 5, if you did not remove the little plug in board, e prom, you may have damaged that. B-4/after changing caps what is the indicator light, green, doing?
Does light stop? Please rtn with more info.
Jun 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
