Question about Rowenta DZ5080 Iron with Auto Shut-off
Rowenta dz5080 leaks from bottom of soleplate
How to repair leaking from soleplate
SOURCE: Water leaks from the bottom
Yes it is from the bottom of the boiler from a small opening, I guess a vent. Thank you for the help.
Posted on Jul 11, 2008
  • 11 Answers
SOURCE: Rowenta DZ5080 iron -lost manual - how do you go
I prefeer to put calgon in the tank where you put water.
Posted on May 12, 2009
brnspncr
  • 67 Answers
SOURCE: THIRD leaking Rowenta
Try buying a cheap one from wallmart or some similar store. They are not too dear so you can use them until they fail and then buy another cheap one.
Posted on Aug 04, 2009
maintenacemi
  • 95 Answers
SOURCE: water leaks
poly seal{white} perished where comes from tank to element plate
Posted on Nov 18, 2009
heatman101
  • 43501 Answers
SOURCE: my iron is leaking from the soleplate rowenta
Here is a tip that will help tou figure out your problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
Leaking water around base
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
God bless you
Feb 03, 2013 | Rowenta Irons
Want to send back for warranty. What is the address I live in Canada.
The Rowenta site can be found here:
http://www.rowenta.ca/rowenta/frame.aspx
To find your nearest Service Centre, click on Consumer Care on the bottom menu bar and then on Service Centres on the left side menu.
Before returning for warranty I would recommend you contact the company for instructions. Click on Contact Us on the bottom menu bar to open a web form.
Apr 25, 2011 | Rowenta DZ5080 Iron with Auto Shut-off
The green arrow on the controll dial lights up,,there is continuity through the soleplate but there isn't any heat
If you are getting continuity from the plug to the soleplate (other than from the ground/earth pin), I would suspect the heater element is broken and is touching the soleplate.
Jan 10, 2011 | Rowenta DZ5080 Iron with Auto Shut-off
My iron is leaking from the soleplate rowenta actipress DM160 iron
heatman101
Jun 10, 2010 | Rowenta ActiPress DM160 Iron
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
My iron leaks water from the bottom
Here is a tip that will help you with that problem...
heatman101
Dec 28, 2009 | Rowenta DZ5080 Iron with Auto Shut-off
Water leaks from bottom as fast as you add it. It
Sounds like the tube ot tank is ruptured. It may be cheaper to buy a new one from wallmart or similar store.
Jul 30, 2009 | Rowenta Professional DM890 Iron with Auto...
Rowenta DZ5080 iron -lost manual - how do you go about the "self-clean" ?
I actually found the manual online - copied the pages needed for my wife to confirm how to perform "the self-clean". Took a while surfing but worth the time. Thanks.
May 11, 2009 | Rowenta DZ5080 Iron with Auto Shut-off
The iron leaks from the base when at rest (up
THAT SHOULD HAVE A WARRANTY. SEE THE STORE MGR. WHERE YOU PURCHASED IT.
Apr 22, 2009 | Rowenta DZ5080 Iron with Auto Shut-off
Rowenta DZ5080 Iron with Auto Shut-off Logo
209 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
