Question about Samsung CLP 315 Laser Printer
Paper jams every single print job!
I own 2 CLP-315 printers and they both jam every single time I print. I only use 20lb paper, envelopes, or laser checks...I bought them at Office Depot last year...love the design, but how can I fix this ongoing issue???
I have found the CLP-315 to be difficult with envelopes. However, I have been able to get it to print them when I load only a few into the tray at a time, ensure that they are pushed all the way up to the front, and the "guide rails" (plastic blue things) are pushed up gently against the side and back. This has worked for me with 4 1/8 x 9 1/2 envelopes. Shorter envelopes might be more tricky since the rear guardrail does not push up far enough.
Posted on Jan 01, 2011
  • 24 Answers
Factors that affect it for me:
  • the moisture: keep it sealed till it goes into the printer, store it in a cupboard with a low-wattage bulb to dry it
  • which way up the paper goes in (feel the surface of the paper carefully with a finger tip - faces are usually smoother or not)
  • the grade of paper: mine won't use paper I have printed on already
  • change brand of paper,
  • only one type of paper in tray
Michael
Posted on Jun 22, 2010
  • 96 Answers
Clean your printer.
Posted on May 28, 2010
CLP-310. paper jammed and it can't be removed. Can the roller be removed to get the paper out? that's the only way the jammed paper is going to come out.
I would recommend that you take it to a authorized printer repair shop and have them remove the paper. Printers have sensors that if not properly installed upon servicing the machine it will give error codes and stop the unit from printing.
When I have paper jams on my printers I always pull the paper from the discharge side to prvent any sensors being bent or broken. Good Luck!!!
Sep 21, 2010 | Samsung CLP 315 Laser Printer
Hi my samsung clp 310 printer regularly jams paper halfway to completion. ....
Hi
Please look at the printer properties under Paper, you will see that the type of paper used can be chosen.
1. This apparently makes the printer behave differently when the default is not chosen.
For example, when I choose Thick Paper, the printer feeds the paper inside the printer much slower than when default is chosen. This, most likely, is done to prevent the paper from jamming up somewhere inside from feeding too quickly.
Therefore, if one is finding that their printer is constantly having a paper jam, changing the paper type may have positive results.
2. Heat maybe another source of paper jams. Although there is no paper jammed in the laser printer, the laser printer may stop printing due from overheating. Therefore, if heat is the culprit, changing the paper type may not work.
Hope this helps !
Jul 22, 2010 | Samsung CLP 315 Laser Printer
My samsung printer clp 315 has a paper jam with about 1/3 of the paper out the exit everytime
From You Tube:
http://www.youtube.com/watch?v=5fJHykzkfww
DIY video tutorial on how to repair the Samsung CLP-315, CLP-301 laser printer "paper jam" problem, where the paper stops printing about halfway through for no apparent reason. My printer worked great otherwise, but was out of warranty. It would have been less expensive to get a new printer.
The problem is a very cheap sensor.
This repair takes 15 minutes and is inexpensive. Read the comments below.
I got the part from SamsungParts.com. Search for part #0604-001393
Jun 16, 2010 | Samsung CLP-315W Laser Color Printer
Samsung clp 310 printer regularly jams
if your printing is halfway to the exit. it is most likely the exit sensor is mulfunction.
get the exit sensor replace.
May 14, 2010 | Samsung CLP 315 Laser Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
My Samsung 310 printer is giving a paper jam message inside warning when I turn the printer on and yet there is no paper jammed inside. Cannot print. Been working fine before. Mayb 100-150 pages printed...
Chek paper size (A4, letter...etc)in driver options and compare it whit your file settings (fo example - you trying to print something whit paper size A4 but printer expect letter format...etc)
Clean paper feed roller
Apr 08, 2010 | Samsung CLP 315 Laser Printer
My piece of cardstock paper keeps jamming barely out of the tray. is there something i can do to have it go all the way through. I have a samsung clp-315 laser printer.
Yes, you have to change the print properties on the computer to let the printer know it is using cardstock. Please refer to the owners manual to get the information. The manual can be found at www.samsung.com under the support section.
Nov 26, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-315 prints half a page and then stops & jams. Interior is clean. Our CLP-315 is doing the same thing. Only had it 6 months. The paper stops printing half way through and you have to open the...
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
May 26, 2009 | Samsung CLP-315W Laser Color Printer
SAMSUNG CLP 315 paper jam
the printer may be detecting dust or something on the sensor, and detecting it as a jam
try to get the sensors cleaned, tell us how you go
May 19, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP 550N paper jams
Make sure the paper guides are not too tight and always fan the paper to rid static build-up before loading.
Jan 19, 2006 | Samsung CLP-550N Laser Printer
Samsung CLP 315 Laser Printer Logo
402 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
