Question about Fuji FinePix S1000FD Digital Camera
Camera keeps taking black pictures in bright light. Some have very dark and like no color. I have tried different settings, and it happens on most the others.
  • 538 Answers
Could be 2 things.
Defective CCD or stuck aperture magnet(closed position)
Both problems are expansive to repair.
Posted on May 27, 2010
SONY DIGTIAL
You never should use the picture you see on the monitor of the camera. Not one camera has a calibrated screen. And the brightness is changed very easy in the setup menu.
To test if your camera shoots good pictures, select AUTO on the mode dial. Shoot some pictures and look on the PC or just print them.
Your camera has so many settings, that over rule the brightness when you switch to it, like + and - 2 EV setting. But when you chose for A, P, S, or M, the pictures can be to dark or to bright, if you dial in the wrong settings. So don't evaluate the pictures on the monitor. Only use the histogram on your camera to see if you have a correct, to dark or to light picture.
Jan 06, 2014 | Panasonic Lumix DMC-TZ3 Digital Camera
What is the purpose of an R2 filter?
Each filter intensifies its color and darkens others, especially the color opposite on the color wheel. They're not of much use in color photography, unless you want weird color casts, but they come into their own in black&white photography.
For example, a red filter intensifies red and darkens blue. It can make a sky look almost black, making clouds pop out. Similarly it can darken foliage. A green filter on the other hand will brighten foliage.
If your camera can take black&white photos, try taking pictures of a red rose with green leaves with and without the filters. With one combination the rose and the leaves will be the same shade. With a red filter the rose will be bright against the dark leaves. With a green filter you'll get a dark rose with bright leaves.
With digital photography you can achieve the same effect in postprocessing, but some times its easier to get the result in camera.
Apr 28, 2012 | Quantaray 55mm Red R2 Lens Filter
After taking pictures with bright colors, image in the viewer blink black/white over brightly lit objects...Help, it's making me crazy!
You're seeing blown-out highlights. These are the portions of your picture that have been so overexposed that they've gone pure white, losing all detail. This is generally considered a bad thing so the camera is warning you about it. But the camera doesn't know what you're taking a picture of, things like the sun reflecting off polished chrome should go pure white, so it's just a warning.
Usually the proper fix is to reduce exposure, bringing back the lost details. This risks losing details in the shadows as they go pure black, but that's generally considered not as bad. After all, we don't expect to see things in the dark.
That was the long answer. The short answer is to press up/down on the multiselector to cycle through the different views of your picture.
May 18, 2011 | Nikon D80 Digital Camera with 18-55mm Lens
My Canon EOS rebel suddenly won't take pictures in dim light. The flash pops up and blinks and blinks trying to register the image but won't ever autofocus and take the picture. The light has to be very...
To autofocus the sensor needs a fair amount of contrast (light and dark eges) to operate. If you're trying to take a photo in a dim room of a dark colored subject for instance the focus won't lock and the camera won't take the picture. Try switching your lens to manual focus and shoot that way.
Jan 07, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Really Dark Viewfinder
That would explain the darkness if the lens is stopped down. It would seem the aperture control is faulty on the camera body. Normally, the aperture remains open until you take the picture. It is only closed down while the shutter is open.
Feb 11, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Repair of digital camera
If you see all black in the viewfinder something bad has happened to the lens. It could be stuck, tilted, etc.
It will need to be taken apart and serviced by a trained technician.
Nov 14, 2007 | Nikon Coolpix 5700 Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Why do some of my pictures come out dark or with shadows?
Your Polaroid Fun! Digital 320 camera does not have a flash. If pictures are coming out dark, it's because there wasn't enough light in the surroundings when the picture was taken. Remember, it's important to take photos in brightly lit surroundings. When taking pictures indoors, make sure that the room has bright lighting. For best results, take pictures during daylight hours with a combination of indoor and outdoor light, preferably near a window.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Fuji FinePix S1000FD Digital Camera Logo
178 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
