Question about Magic Chef Kitchen Ranges
Magic chef model# cer3725acw. Using stove top burner.(CAL) Error message came on briefly on touch pad display window. Can't change time on clock,turn on oven,set temp.or timer.Burners work fine. Unplugged stove and let it sit for an hour.Then plugged back in.The colon flashed on clock.Tried to reset clock but it went back to same do nothing mode. If you can help or not thanks Glenn
    President:
  • 949 Answers
It sounds like a bad control. Before replacing the control, make sure it is not in Sabbath Mode, Child lock and if all else fails try resetting the control to factory defaults. If none of these work then replace the clock/control part number 5701M827-60. This part runs about $175.00
I attached a cut out of the service manual, to show how to reset the locks and factory defaults
Posted on May 27, 2010
Testimonial: "Thanks for your advice.I tried resetting but I think the part you mentioned will have to be replaced."
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Nov 20, 2010 | Magic Chef Kitchen Ranges
Magic chef code f1
Hi sundownman,
F1 error description is a defective touch pad or clock (ERC). To resolve this error, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Nov 09, 2010 | Magic Chef 31000 Gas Kitchen Range
Oven does not get hot F1 F7 error message. one burner does not
Hi there
Heres the codesfor you and hope this helps and let me know.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Thank you for writing to fix ya.
Best regards Richard
Feb 12, 2010 | Magic Chef 31100 Gas Kitchen Range
Magic Chef gas stove periodically starts beeping and "F-1" appears in the display
Hi alflaw,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Feb 05, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic chef stove model # 6898VRA keeps setting off alarm f1 why?
Have you tried to Turn it OFF and then Turn it ON.You could also try Pushing Multiple Buttons, if that could help.
If not, i am afraid that this is a BAD CONTROL BOARD / TOUCH PAD error. You need to replace either or both of these. Once done, it would Fix the Problem.
Some Models do Incorporate Touch Pad and Clock Control as One Part. So, that means you Could have Bad Clock Control.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 19, 2010 | Magic Chef CER1115AA Electric Kitchen...
The oven on my magic chef range does not work..broiler and burners ok ,,,get a F1 code and beeping noise ...model number 3488VTV
Hi hockeyhoskin,
Hope it helps.
Dec 06, 2009 | Magic Chef 31000 Gas Kitchen Range
F-7 and beeping is occurring on my Magic Chef,
Hi sixgunromeo,
The error code F7 means that the Function key is shorted or stuck. TO fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Dec 05, 2009 | Magic Chef 31000 Gas Kitchen Range
Keeps beeping and displaying F1
Hi clnee,
Hope it helps.
Sep 26, 2009 | Magic Chef 31000 Gas Kitchen Range
Constant beeping and F7 is displayed
Hi tahitian,
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Dec 16, 2008 | Magic Chef 31000 Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
337 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
