Dear Support team, I have a smartdisk 80GB FireWire Hard Drive Model FWFP80EU. I had this connected to my previous mac. i have now sold mac for a toshiba P100 satelite which does not seem work. Also have not got original smartdisk installation cd. I have all my work in this hard drive and need to access asap! What can i do?
    Scholar:
  • 50 Answers
Smartdisk's website reports that drives with model numbers beginning with "FWFP" do not require a driver to work with Windows 98/ME/2000/XP. You may want to check to make sure you are plugging the drive into a working USB port (switch the port you plug it in to).
Also, observe the way the computer reacts when you plug it in. Do you hear any sounds, or see anything in the lower right corner indicating it's trying to install anything?
Posted on Apr 09, 2008
6ya staff
SOURCE:
Firelite smartdisk does not mount on my Mac
Your drive may be in NTFS file format that is not supported natively by your mac, try looking for NTFS support or reformat your drive to FAT32.
May 02, 2012 | SmartDisk CrossFire Desktop FireWire/USB...
I have a Firelite Smartdisk External 60G hard drive - Model #FWFL60-N which I bought to back up my previous MacBook. It only has FireWire outlets and cable with only FireWire ends - no USB port...
Hi Selina It was a big mistake for Apple to omit the FW port on the white MacBook. The problem you hilite is the reason I don't recommentd the macbook to any of my clients. However, the problem is solveable - although you may/will have to do some breaking and entering.
There is no cable adaptor - nor will there ever be, the protocols are so radically different that they can never talk to each other.
The simplest option is to connect your drive to another mac that has got FW (800 or 400 - it doesn't matter as long as the cable will connect the two units) then use file sharing to transfer the conent of the drive to you MacBook either by ethernet (preferable) or by wifi (much slower).
The breaking and entereing option imvolves opening up the firelilte and removing its HD (it's easy) then get a unit like this Overview or this http://www.maplin.co.uk/sata-hard-drive-usb-docking-station-222999
There are other much cheaper units and they all work fairly well. I have several as I'm up against your problem regularly
Apr 01, 2011 | Computers & Internet
How to use ?? with Mac I don't seam to have software? have been trying to use a long time but have never got very far? I should have taken Firewire back to shop?? when i connect firewire cable to port on...
go to the start menu select my computer. then plug in the device if the device does not pop up you are not getting a connection. check the device to see if the part that goes in the usb port is not loose or have any malfunctions. if you open my computer and you see it when you plug it in double click the port its in to open
Jan 31, 2011 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
I would like to remove all the old data from my Smartdisk usb flb160. How do I do that
Connect the SmartDisk.
Open "My Computer".
Right-mouse click on the icon for the SmartDisk.
Click FORMAT
Click 'OK' to completely "empty" the disk-drive.
Nov 13, 2010 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
I want to reuse this drive on a new MAC, how do I clean the old information off the drive?
Do you want to use it as an external USB hard drive?
If so connect it to a USB hard drive adapter case and connect it to the MAC and either delete the folders and filed OR format the hard disk.
Nov 25, 2009 | SmartDisk FireLite 80GB 400Mbps FireWire...
I'm having problems connecting FireLite portable hard drives to my mc.
1. Check operating system version sometimes its just the version not all mac versions like externals.
2. Under disk manager if the drive does not appear 9 times out of 10 its not compatable with the os your using.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 17, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Smartdisk 80gb has power connection, but data (Mac)
scan the your computer and smartdisk for viruses
the problem you are mentioning about the desktop icons could be due to viruses
also run chkdsk utility on the smart drive after virus scan
Jul 12, 2009 | FireLite (USBFLB80) Hard Drive
Smartdisk 160GB Crossfire hard drive
I had this same problem. One option is to open the smartdisk up. It should have a seagate ata drive inside. Attach it to a computer as a slave drive. Your dive will appear as a secondary drive on your computer. you should be able to get all your files off the drive. If your worried about voiding your computers warranty you can buy a usb adapter to make the drive act as an external drive. I highly recommend never using this drive again. I used it as my main hard drive and it fried on me. If you plan on getting rid of this drive let me. I need the circuit board to get my music files and portfolio off my failed drive. Thank you.
email: biz[email protected]
Mar 26, 2009 | SmartDisk Crossfire Desktop (xf160f) 160...
Formatted hard disk on pc now it won't run on mac
Try plugging your hard drive into your mac, open "Disk Utility" select your hard drive in the list on the side, Click RAID, change the Volume Format to MS-DOS (FAT), and it should work.
Hope this helps!
Apr 03, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Open Questions:
Computers & Internet Logo
Ekse
Marvin
Marvin
