Question about Epson PhotoFine P-2000 Digital Media Player
When P-2000 is turned on it says "Reset". When devise is reset it recycles back to "Reset". Only turns off if power sources (Adapter and battery" are removed.
Have you changed the HDD?
Posted on Jun 11, 2010
Ipod will not turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod.
When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch.
Press any button to turn on iPod.
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge.
iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes.
If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Sep 08, 2013 | Apple iPod Audio Players & Recorders
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
Ipod does not power up
Mar 24, 2013 | Apple iPod Audio Players & Recorders
Dos not work
Reset iPod
hope this helps
Sep 05, 2012 | Eclipse Audio Players & Recorders
Hello, i broke the screen on my laptop wanting to switch it to my desktop monitor but for some reason it wont switch over. unfortunately since i cant see the screen i cant get into my startup menu any...
First, disconnect the laptop from the ac adapter and take off the battery and the memory. Press the reset button on your laptop. Connect your ac adapter only and press the power button two or three time while everything else is disconnected. Then, re-install your memory and your battery. Connect the ac adapter to the laptop and to your power source. Now turn on your laptop and see if you get a display on your laptop screen. If you do, then you have reset everything and you are back to where you started. Good luck and let me know how it goes.
Dec 06, 2010 | Computers & Internet
My new acer aspire 5551-2036 is not working. when i turn it on the acer screen appears but then goes to a black screen but you can still tell that it is on.
Try turning it on then performing a hard reset. Press and hold the power button till it turns off. Remove battery and power adapter for 30 seconds. It should boot right up after that reset. Please provide feedback so we can get to the source of your problem.
Nov 10, 2010 | Acer Computers & Internet
I have to reset the country date time etc every time i turn my camera on, i have tried going through menu and reset but this hasn't solved the problem. Please help
There is a built in battery that can keep the time date etc. info for 20 something hrs. without any other source of power. If your camera has a charged battery, is plugged into an active USB or powered by an adapter and you shut it off and then immediately turn it back on again, what happens? If the clock needs to be reset are you sure that you have completed setting the time. After adjusting all the settings you hit set. Most likely it seems that your internal battery is bad. It should charge when the camera is being powered by the main battery.When you say every time you turn it on I'm not sure what that means. If you turn the camera off and remove the battery for more then 30 hrs. it will have to be reset. If that is the case you need to leave a fully charged battery in long enough to charge the built in battery. If the built in battery is bad you will need to find out if it can be replaced.
Aug 04, 2010 | Casio Exilim EX-Z750 Digital Camera
Blank screen
do a power reset on the computer. turn off the computer. remove the battery pack and unplug the ac adapter. press and hold the power button for 10 secs without any power source to drain all excess power in the laptop. put in the battery first followed by the ac adapter. turn the computer.
i hope this helps.
Sep 12, 2008 | Toshiba Satellite A205-S4617 Notebook
I cant get it to turn on
Hi TweyTwey,
Is this a new router? Are you sure that you are using the correct power adapter, if you are then the adapter might be faulty! Try another adapter. Also, be sure that the wall socket you are plugged into is functioning...test it with a light. There is one other thing you might try. If you look on the back of the router, you will see a reset slot. You can use a pen and push and hold the reset for a moment to cause it to recycle. If none of these things solve the issue then I would suspect that the router is defective.
--RoadHawk
Nov 25, 2007 | Linksys Wireless-G Broadband Router
Epson PhotoFine P-2000 Digital Media Player Logo
87 people viewed this question
Top Epson Audio Players & Recorders Experts
Tom Chichester
David Tickner
Bill Boyd
Are you an Epson Audio Player and Recorder Expert? Answer questions, earn points and help others
