Question about Porter Cable Variable Speed Quik Change Tiger Saw Kit 9746
Cannot get the blade out of the porter cable reciprocating saw
Unlocked the lock but the saw will not release the blade, tried wiggling the blade and pulling but nothing works
  • 43,501 Answers
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Posted on Aug 27, 2010
How do you install new blades on a DW7332?
unplug the saw/remove battery
press the button on the side near the blade
pull old blade out. push new blade in, release button to lock new blade in place.
Jun 06, 2014 | Saws
Cannot put blade into 310 reciprocating saw the instructions in the manual do not make it clear
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
May 25, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
How do you unlock the quikrelease when it is stuck open on the bosch recripcating saw
when you look at the front of the quick release, you should see 2 arrows, the arrow on the right faces up, the arrow on the left faces down. that is the open position, now all you need to do is insert a blade and it will lock closed by itself. then just turn it back to release the blade.
Jan 22, 2010 | Bosch 1646B 18V Cordless Reciprocating Saw...
How do I disassemble a craftsman 10 amp reciprocating saw?
To remove the front half of the saw:
1. Remove the two screws that hold the guide shoe
2. Pull and wiggle the guide shoe straight forward and out.
3. Remove the metal support from the front of the rubber boot by prying it out of the groove.
4. Using a pick or a very small screwdriver, pry the retaining pin from the blade release handle and remove from the front. It removes without much friction.
5. Remove the blade release handle through the side of the saw by wiggling and releasing the return spring.
6. Remove the rubber boot off the front of the saw by gently prying near the center of the saw and firmly pulling.
7. Remove the six screws to remove the black plastic dust cover.
8. Remove the remaining two screws and lift the grease guard to access the reciprocating mechanism, being careful not to drop the needle-bearings. This area can be packed with grease.
The handle part of the saw is self explanatory.
Dec 26, 2009 | Saws
BRAKE DOES NOT STOP BLADE WHEN TRIGGER IS
the guard not releasing could be dirt around the spindle hub or the guard is bent, I would unplug tool and manually pull the guard down to see which one, if it is just sticking you can use a dry lube to cure that, the break could be dirty commutator or worn out brushes, switch. Give me the model number and I will try and find a breakdown for you and go further.
Oct 05, 2009 | Porter Cable Saws
The blade is broken off, exactly flush with the end of the cylinder that holds it. I've tried digging it out, grab the end with pliers, and also hammered nails in the slot behind the blade to push it...
Do you have an old blade that you can cut down to slide in behind it and try tapping on that, also you didn't say what kind of blade lock this has, I just had one that dimpled the blade so I couldn't remove and had to take a small punch and knock the dimple back and it basically fell out. Let me know if i can be of more assistance
Jun 29, 2009 | Porter Cable Variable Speed Quik Change...
Blade won't lock.
There is a ball lock in it and you have to twist the ball lock but if the ball lock is frozen generally WD40 will help unfreeze it and work it until the ball is free and should work just fine.
Jun 09, 2009 | Saws
Blade lock on Craftsman 10 amp recip
The guide foot comes completely out by wiggling and pulling a little harder than you would think. It is held in place by friction in addition to the two screws. Once the guide foot is removed, remove the front metal support piece by prying it out of the groove in the rubber boot. You can then access the pin and blade release lever. Make sure the return spring is in place on the rear side of the blade lock latch.
Apr 11, 2009 | Craftsman 8.0 amp Reciprocating Saw
How does one remove a broken blade from a Bosch rs20 blade holder
twist the collar around where the blade fits in the saw. It will lock in the open position. When you insert the new blade, do so firmly until the collar releases locking the new blade in place. Give a tug at the blade to make sure it is locked in.
Nov 27, 2008 | Bosch RS20 13 Amp Reciprocating Saw
Porter Cable Variable Speed Quik Change Tiger Saw Kit 9746 Logo
571 people viewed this question
Top Porter Cable Saws Experts
Frank Mangiapane
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
