Question about Refrigerators
Bottom freezer freezes fridge does not cool thanks
  • a9730 May 27, 2010
    this last expert cannot even write proper english. the evaproator is not the problem why dont you just make availble all possible solutions. i repair fridges, but have checked the heater element, it's fine, defrost timer is fine, evaporator fan is fine, i want to know if possible frige damper is not functioning or what other possibilities. you are not talking to a dummy here. thank you roger anderson.
  • 1,284 Answers
Hi, if you are having trouble with the freezer working fine but the refrigerator not cooling then the defrost has not cleared all the ice in the coils. Try a manual defrost by unplugging your refrigerator and let it sit for a couple of hours to clear the ice. Plug it back in and see if it re-ice's in a short amount of time. Over a week or two. If so then you may need to have your defrost timer replaced. This process can save you hundreds in service charges.
Take care
Posted on May 27, 2010
  • 2 more comments
    have replaced the defrost timer so what is next?
  • Shehu Pro
    Shehu Pro May 27, 2010
    Hi, Refrigerator not cooling, is ice forming on back of side-by-side freezer?
    Turn off unit. Empty freezer section. Remove freezer back panel (4
    screws) to expose iced-over coils. Use a fan to speed up defrosting.
    Put a towel or a plastic drip pan in the bottom of the freezer to
    collect melting water (rather than letting the water collect and maybe
    overflowing in the drip pan underneath the refrigerator).
    After defrosting, by temporarily replacing the freezer back panel and
    turning on the unit, the refrigerator may operate OK for about 3 weeks
    before the next excessive ice build up.
    Possible problem- a burned out Defrost Heater.
    To check: After defrosting, turn off power to or unplug the refrigerator.
    Unscrew the Defrost Heater bracket (2 screws). When loose, unplug the
    two wires connected to the unit. Have the unit checked, or use an
    ohm-meter to check continuity. If unit measures "open", high
    resistance, replace the Defrost Heater and bracket. If the heating
    element shows continuity (or low resistance) the heater is probably OK
    and you have another problem.
    Take care
  • a9730 May 28, 2010
    heater is fine defrost timer is fine fan in freezer is fine whats next. how about damper in fridge. whats next????????????????
  • Shehu Pro
    Shehu Pro May 28, 2010
    O.k, you can check the damper in the fridge...
    Genius:
  • 1,416 Answers
please answer these question !
so that you can then follow this advice below as a guild line
his your freezer newly but with guaranty or warranty if you r answer is YES and the agreement date is still on . then what you need to do is that return the freezer back to the store for replacement or service i.e for fix up it will be free off change together with the agreement form, i mean your receipt
but if the answer is NO then you have to do the fixing up your self by changing the condenser of the fridge
your statement tell that the condenser is bad i.e thereis a leakage some were around it were gas flow out freely
it's this condenser that pass out gas from the compressor to the freezer it self
please note information the condenser is in form of net at the back of the your fridge and it always in black colour , do change this then your freezer will work out find again
Thank you and thanks for using fixya.
I have a Maytag Bottom Freezer that the freezer is frozen and the fridge is warm?
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 27, 2011 | Refrigerators
Amana fridge is not cold
Oct 26, 2011 | Amana ABB1927DE Bottom Freezer...
Fridge not cooling.
Oct 23, 2011 | Candy CPCA240FFK Bottom Freezer...
My amana refrigerator is not cooling, freezer is working
Oct 22, 2011 | Amana ARB2217CSR Bottom Freezer...
Fridge not cooling... Freezer is fine
Sep 12, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge is not cooling. lights are working. freeer is working
Jul 24, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
FREEZER WORKING FRIDGE NOT COOLING
Jul 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Fan is running but the fridge is not cooling at all
Jul 11, 2011 | Maytag 22.1 cu. ft. Bottom Freezer...
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
