Question about Maytag Neptune MAH5500B Front Load Washer
Washer will not restart
We had a power outage and it tripped the circuit breaker. I have Tripped the breaker and unplugged the washer and back in. It will still not start back. It is a Neptune washer.
    Novelist:
  • 132 Answers
There is a main control board on top which may need to be replaced,
if you remove the back top panel there is a tech sheet with a lot of information tucked in there, Suggest you plug something else into outlet to make sure outlet has power, and breaker is still ok,
good luck
Posted on May 27, 2010
Why wont frigidare affinity FAFW4011LWD start after the power went out? No lights come on, nothing.
Good Afternoon Friend,
I understand you are not receiving power to your Frigidaire Affinity washer, model# FAFW4011LWD. I also see that there was a power outage before the symptoms began. I suggest checking the fuses or circuit breaker to make sure that it has not been tripped. If the breaker has not been tripped, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire Washing Machines
Tripped my circuit and wont reset or start HELP!!!
Your circuit braker tripped because of a current problem that in your case caused a defective part. Since your machine is still under warranty, best way will be to contact to the appropriate factory service center for repair the problem. Good luck!
Aug 22, 2007 | EuroTech EWC177 Front Load Washer / Dryer
No power to the display, dryer will not turn on
First thing you need to do is check the Circuit Breaker for the dryer. If it is tripped unplug the dryer and reset the Circuit Breaker. Now plug in the dryer and try to run it. If it does not work again check the Circuit Breaker again if it is tripped again unplug dryer and call someone that can help you or fix it. If the Circuit Breaker is not tripped check for good power readings on both power lines coming into the dryer. Should have 110V or more on each line to neutral, and 220V or more between each line. If you do not have the correct voltage at each line check Circuit Breaker for good power coming out.
Mar 13, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
After power outage dryer will not come on model # 96573220
Hello Edward, Is it possible that the electrical circuit breaker is tripped in your breaker box? Try shutting the breaker off and turn it back on.
Feb 23, 2014 | Kenmore 60172 Electric Commercial Dryer
Whirlpool WFW9150WW00 won't start after tripped circuit breaker
the motors internal fuse link may have burned thru..this is not a user serviceable part.. calls for another motor..
Jan 12, 2014 | Whirlpool Washing Machines
Viore tv won't power up after power outage.
I would first test the outlet. Unplug the TV and plug in your vacuum or other loud or bright object. Turn on test object - if there is no operation, then you have a tripped circuit breaker. Find the electrical panel ( Grey box mounted into a wall, usually in a closet). Find the tripped breaker ( typically the switch will be halfway between on and off, and many have a red indicator by the switch base). Turn switch to off fully, then back to on.
Retest outlet.
If still no power to outlet, unplug everything from that outlet and call an electrician - there may be a serious problem with the wiring!
Hope this helps!!
Dec 02, 2013 | Televison & Video
Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Jan 11, 2010 | LG WM1814CW Front Load Washer
3-pole 60 Amp Circuit Breaker is tripped and won't reset.
When this breaker tripped, it did not go fully to off. Push the breaker all the way off and then all the way to on. It should be fine. If not manually push it to full off once again and then back on. If both attempts fail the breaker will have to be replaced. good luck.
Jan 25, 2009 | RTO Cutler-hammergd3100 100amp 3pole...
Powercom BNT 1500AP quit working after power outage
From your description it appears one or more batteries are bad..The circuit breaker on the Power Strip..which more then likely is a 15 Amp..tripped due to over current conditions..check the batteries and reset the circuit breaker..That should take care of it
Dec 28, 2008 | Powercom (BNT-1500AP) UPS System
Maytag Neptune MAH5500B Front Load Washer Logo
276 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
