5 amp fuse burns out - Heating & Cooling
  • tdhall2 Sep 20, 2009
    i figured out that the wires inside the unit were rubbing. everyone in my area has had this problem since they were installed by the same company
  • 236 Answers
Replace with the same rating fuse, but if still burn out or will not function then there is something wrong with the unit. You need a qualified technician for thorough checking.
Posted on Apr 08, 2008
I have a 98 Tahoe 4x4 5.7 and a fuse keeps blowing within minutes number the hood compartment it's labeled (eng 1) 20 amp
FUSES BLOW BECAUSE THE COMPONET THAT IT PROTECTS IS EITHER PULLING TOO MANY AMPS OR YOU HAVE A SHORT. LOOK FOR BARE OR BURNED WIRING
Dec 23, 2014 | Cars & Trucks
Tip
Car stereo wiring do it yourself. bare wires and fuses.
when installing a car stereo, always i repeat always tape up or put a connector on any and all wires. even if they are not used. you dont want any bare or naked wires flopping around. some of the wires may control the illumination or dash lights. you could mess up alot of stuff. also, make sure the right size fuse is used in your fuse box. if the fuse is supposed to be a 10 amp, put a 10 amp fuse in it. ive seen people use a larger amp fuse or take wire or tin foil and wrap it around a fuse to make it good again. this is one of the worst ideas to have. this could potentially burn down your vehicle. also, if you have an amplifier, or aftermarket fog lights, or anything extra on your battery. make sure you have it fused with the right amp rating fuse. failure to do so will most likely burn the wire, wiring harness, burn your vehicle.... bad idea. always use the right fuse.
on Dec 27, 2009 | Car Audio & Video
Firnace burning tht fuse
clean dust out of it check all connections are tight
fuses up to 13 amp 3000w 1500w 5 amp 750w 3 amp
Dec 12, 2014 | Heating & Cooling
Fuse for brake lights keeps burning out
If at this time you haven't really damaged your truck, do this. It doesn't matter which way you go, you must check your wire for a bad SHORT. Your brake light wire is pinched,or rubbing on metal. Remove the wire, don't use 30 amp if 20 amp is correct. If you've done any work on your truck that involved wiring, look in that area. GOOD LUCK FRIEND.
Jan 18, 2014 | 1998 Chevrolet K1500
My blower motor resistor burned up I'n my 05
Are you putting the right amp fuse in place of that fuse was at ? If you have a fuse that is 5 amps smaller could produce this same problem so go make sure your manual says what amp fuse goes there first. This might solve the issue. Usually if the fuse keeps breaking inside of it means that there might be a short some where else.
May 24, 2011 | 2005 GMC Sierra Denali
So i hooked up the amp useing the pre-existing 8 gauge wire with a 30 amp fuse it worked for about and hour and started blowing the 30 amp line fuse. i replaced the line from 8 to 4 gauge and installed an...
this sound like a case of arcing power wire it happens very very easy if u use cheap wire especially from walmart. whatever u do keep using fuses and get a batt test asap. if u take out the fuses ull burn the amp like no other and plobably burn out the power rails which will be cheaper to buy a new amp after that
Oct 05, 2010 | Lanzar VIBE266 Car Audio Amplifier
KEEPS BURNING FUSE FOR POWER WINDOWS/LOCKS ITS PINK SQUARE 30 AMP
check ur trunk where there is a cap thing back there where wires run to make sure that didnt burn i have 1998 camry that did the same as urs and i checked mine and i fixed mine and now everythings works now
May 27, 2009 | 1996 Toyota Camry
The fuse from the amp to the battery keeps burning
maybe it cannot accomodate too much power running on it...too much current, try another fuse with higher ampere rates
Jan 14, 2009 | Nitro BMW-486 Car Audio Amplifier
Heating & Cooling Logo
242 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
