Question about Whirlpool Kitchen Ranges
#8053291 Self Cleaning Will not come on Has code PF & FOEO
    President:
  • 949 Answers
PF stands for power failure, meaning the power to the appliance was lost or the control board thinks power was lost temporarily.
The other code is below. Try turning the circuit breaker off for a minute or two then back on, if this does not fix the problem you will need to have the circuit board replaced.
Posted on May 27, 2010
Kenmore ultra bake self cleaning super capacity electric oven is showing the letters pf in red what could this mean?
PF usually just refers to power failure. You should only have to reset your clock and then check to make sure everything else works.
Jun 15, 2015 | Kenmore Ovens
What does the message PF mean?
PF = Power Fail. Possibly damaged control board.
Dec 23, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
My frigidaire oven overheated last night, we unplugged it and replugged this morning with a PF on the face. The plastic has melted a little. What should we do?
Good Afternoon Friend,
I understand that your Frigidaire range overheated, so you unplugged it and plugged it in the next morning. I also see that when you plugged it back in there was a "PF" code displayed as well as some melted plastic. The "PF" code means that there was a power failure. You can clear that by pressing any button. As far as your appliance overheating and melting plastic, I suggest contacting the manufacturer directly for further assistance. They might be able to point you in the right direction to have it repaired. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire Gallery 30" Self-Cleaning...
Code p1445
P1445: CHECK PF SENSOR HIGH VOLTAGE TO PCM
Continuous Memory Diagnostic Trouble Code (DTC) P1445 indicates that Self-Test has detected a PF sensor circuit input above the maximum.
Possible causes:
PF shorted to VPWR.
PF open circuit.
PWR GND open circuit.
Damaged purge flow (PF) sensor.
Damaged PCM.
Jul 24, 2011 | 1996 Mercury Cougar XR7
During cleaning process, blew house breaker. Reset
Seems like you found out the hard way what I wrote about in this tip...
Yuor wiring has been incinerated with the stuff in your oven...
Yes, it can be fixed, depending on what and how much has burnt...
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 23, 2010 | Kenmore Ovens
No the top heater elements don't come on. At the digital readout give a message of err PF5.
Hi.
PF means power failure. and it is not an error code.
To reset the PF code:
Hold down Clock or Bake pad (depending on model) for up to ten seconds.
If that does not work, trip circuit breaker, or disconnect power for one minute.
If still no luck, then it is worth a call to manufacturer, at the number listed on the owners manual.
You may get error PF5 when there is a wiring problem, sometimes after a self cleaning cycle damage, or when there is door lock failure.
Jan 25, 2010 | Kitchen Ranges
Oven wont unlock has a pf code? cant open the door!
PF refers to Power Failure.Press Cancel and Check, if that clears the error. If the problem persists, it might be a Faulty Control Board.
Now,
Before that, as you never mentioned Did you try to use Self-Cleaning? If yes follow the below procedure :-
1. Unplug the Circuit Breaker for 5 minutes.Turn On the breaker and then try to open the door.
2. Again go for self clean option but for few minutes, say 15 minutes.Cancel the self self after this and allow the Oven to Cool. After some time, then try to open the door.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | Kenmore Kitchen Ranges
I am getting a PF code - I have a self cleaning - accubake system electric silver with black top and sides - not sure how old the oven is
the "PF" simply indicates at some point the power to the unit failed, hence the "PF" (power failure). turn the range breaker off for a minute or two, or unplug it for said amount of time. after that if you push the cancel bottun on the control it should go away, then you can set the time of day/clock etc.
If that doesn't get it right, make another post on here and we'll go from there.
hopefully it's that simple :)
good luck
Sep 29, 2009 | Whirlpool Ovens
Oven lock will not open
my self cleaning oven door will not unlock what do I need to do?
Jan 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
283 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
