Question about Sony Playstation 3 (PS3) Console
Cannot start hard disk not found - Sony Playstation 3 (PS3) Console
    President:
  • 2,653 Answers
That almost certainly means your hard drive has crashed.
You can swap it out with any 500gb and below SATA laptop drive. Right now Best Buy has a 250gb drive for only $50, or you can get a smaller drive from NewEgg.com for next to nothing.
Just swap the drives, turn on your PS3 and follow the steps on the TV and you're back in business.
Hope this info helps!
Posted on May 27, 2010
Operating system not found
there is problem with your hard disk. your hard disk wire may be loose. try to remove and refix all sata wires of your hard disk. "operating system not found" message may be coming because you may have not installed any os (windows, linux or mac) in your notebook. try to install operating to system to fix this. there may also be proble with your hard disk, your hard disk may be dead. if your notebook is showing message "operating system not found" without any reason then you may have put your notebook in high magnetic field area. due to high magnetic field, sometimes hard disk's are formatted automatically.
Apr 10, 2013 | Samsung N150 Notebook
Ps3 cannot start hard disk not found
The hard disk may be faulty. Try reseating the hard disk if the PS3 still cannot find the hard disk then it is faulty and a new hard disk is needed and the PS3 software needs to be installed on the new hard disk.
Dec 05, 2011 | Sony Video Game Consoles & Games
Ps3 slimline says cannot start the correct hard disk was not found
Dear Friend,
Have you consider to replace your hard drive?. That might be a good possibility why your PS3 can not start the way it should. Try that and see what happens.
Good Luck!
Nov 26, 2011 | Sony Playstation 3 (PS3) Console
Please give me solution for the hard disk error [ E 602 - 001, 002 ,003 ] in canon ir 8500 . i need the full suport of this problem
The wiring is faulty (short circuit, open circuit, disconnection). The installed
system file is faulty. The hard disk drive is faulty. The main controller
PCB is faulty.
Condition
0001 A fault is detected in the mounting of the hard disk when the system
on the hard disk is started up using the BOOT ROM.
0002 The appropriate system file cannot be found on the hard disk when
the system on the hard disk is started using the BOOT ROM.
0003 A sector error occurs on the hard disk when the system on the hard
Nov 15, 2010 | Canon imageRUNNER 8500 Copier
Cannot start. The correct hard disk was not found.
u will have to get a new hard drive i would get this one it is cheap http://www.walmart.com/catalog/product.do?product_id=10710953
you will have to take the cover off the hard drive.
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Cannot load operationing system because of fault saying, "no hard disk found in this computer"
Check the data cable. Make sure it is fully connected. (Sometimes they come loose). Check all connected data cable's & power cables within the system. Start with the new drive you installed. Unplug the data cable & re-connect. Follow it to the motherboard & do the same. If no cable seemed loose than replace the hard disk drive's cable with a new cable. Standard 80-conductor Ultra DMA IDE/ATA interface cable. See below;
ab2779a.jpg When you start up the dimension 4600, enter the bios, watch your screen at start up. You will need to press F2 or F10 key to enter the bios.
Once in the bios check that you hard disk drive is shown.
Most bios will list the drive by its model number. If you see the model number of the drive chances are you can save & exit the bios. Button up the case. You should be able to load windows.
Luck!
Mike
May 05, 2009 | Dell (E210882) Motherboard
No operating system found
This is caused by :-
1. Your hard disk has failed.
2. Your BIOS settings for the hard drive has been altered
3. Your hard drive has been wiped or someone or a virus program that has deleted critical files.
Go into your BIOS setup to check the hard disk settings, if possible see if it will auto detect the hard drive.
Also boot up with a DOS disk run FDISK to see if you can detect a hard disk, partitions etc.
If the hard disk appears OK you may be able to do a disk repair, most likely you would need to re-install the operating system and the laptop drivers for video, audio, LAN, modem etc.
Nov 15, 2008 | Sony VAIO VGN-FJ270/B Notebook
Hard disk
remove your hard drive, power on teh console, power off the console, install the hard disk again and power again the console.
Hope this will make the system recognize the hard drive again.
Sep 01, 2008 | Sony Playstation 3 (PS3) Console
Hard disk not found?!
i thik u have to format the hard disk and try it again. or may be u have change to the security settings.
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
65 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
